Old 11-07-2010   #31
HIZNHRZ
Default Re: GS-D3 demise rumor,( again! )?
Originally Posted by ScottZ95ZR1 View Post
Just FYI - I see a vendor over on CF has several sets of brand new OEM polished and clear-coated Speedline C6Z wheels for $795 and shipping.
http://forums.corvetteforum.com/c6-p...peedlines.html
Scott,
Thanks much for the heads up. My wife is going to have a Canary but if these are really OEM wheel, this is just too good to pass up.
Scott
Old 11-07-2010   #32
RICKYRJ1
RICKYRJ1's Avatar
Originally Posted by HIZNHRZ View Post
Ricky, do you have a manufacturer and part number for the adapter that has its own set of studs? It would be great to be able to interchange the ZR-1 and Z06 wheels.
Thanks.
I will get it for you tomorrow, I need to dig up the receipt.
I went with the adapters because if I went with just spacers I would have had to change out the rear studs to longer ones. All I had to do with these was trim off the non threaded (tip) of the factory studs (5 min of time) and I was good to go.
Old 11-07-2010   #33
ScottZ95ZR1
ScottZ95ZR1's Avatar
Originally Posted by RICKYRJ1 View Post
This was the best setup for me because I change between my 2 sets of wheels often (Kinesis show & Z06 DD)
Hey Rick, will you still be able to use those sweet Kinesis wheels after you upgrade to the C6Z brakes?
ScottZ95ZR1 is offline   Reply With Quote
Old 11-07-2010   #34
RICKYRJ1
RICKYRJ1's Avatar
Yes Sir! I have been running the fronts all year and soon will complete the backs. I was told in the past that they wouldn't clear the caliper so I was going to sell them cheap. How happy was I when I discovered that they cleared fine? Saved a lot of money not having to by new wheels.
Old 11-07-2010   #35
ScottZ95ZR1
Good deal! I didn't catch that you already have the fronts installed.
Old 11-08-2010   #36
Jagdpanzer
Jagdpanzer's Avatar
I'm thinking about a new set of wheels and trying to decide on which direction to go on rear tires. Anyone here running 345/30ZR19 size tires on the rear of their Z? They are a little wider and taller than the 315/35ZR17s tires the Zs came stock with but should fit with the right offset wheel.
Old 11-08-2010   #37
Dom and Ricky are running 345's on the rear.
Old 11-08-2010   #38
Frank,
Those were 325's which is the stock Z06 tire.
Old 01-11-2011   #39
Mika73
So it really isnt possible get GoodYear F1 Supercar 315 tires anymore.. Course I have those at my -90 ZR1. I need new tires to rear and think I am getting those other GoodYear tires that look like V.
Mika73 is offline   Reply With Quote
Old 01-11-2011   #40
The F1 supercar version has been out of production since about late 2005 or 2006. I do not know what G/Yr replaced it with.
The "V" shaped tread are the GS-D3. It seems that G/Yr has had another run of the D3's as Tire Rack now has the 315's in stock.....but the 275's are now out of stock as of last week.
