#31 |
![]() Join Date: Jul 2005
By scantool are you refering to a Tech 1? I do have one with correct ECM cartridge. The system is holding vacumn. The pump comes on for a few seconds when the key is turned on and then shuts off and stays off.
#32 | |
I wouldn't mind having a Tech 1 myself. Yes, it's a scantool. When you go Key On and secondary pump cycles, what is the reading for the Diff MAP sensor voltage? If the pump is shutting down, that tells me sensor is reading correctly and signaling ECM that there is sufficient vacuum to run secondaries. That would lead me to think it's not MAP sensor. If secondaries were not operable you would get a code 55? I think as well. If just getting code 61, then it's a Lean O2 condition which is shutting down the secondaries. So the issue is why is A/F going lean. |
#33 |
![]() Join Date: Feb 2006
Hey John,
I just replaced both on my 90 with ACDELCO's, under the ECM the acdelco box it came in states the same no. for ac/gm ACD# 16232241 GM# 16232241 MAP SENSOR back of plenum ACD# 213-1545 GM# 12569240 ![]() Luis |
#34 | |||
![]() Last edited by Dynomite; 05-09-2010 at 08:17 PM. |
#35 |
Thanks bro's!!
#36 |
I want to close this post out. I had broken #5 secondary port throttle valve shaft. It was broken in two at the center screw point. Must have been a factory fatigue flaw. Or maybe I hammer the secondaries too hard
![]() Thanks to the ZFDoc for getting me back on the road and to Andrew for supplying with the secondary parts. Next go around the entire secondary system is coming out ![]()
#37 | |
