Old 02-03-2010   #31
tpepmeie
Default Re: intake port molds
It would be very interesting to see some dyno curves with your IHs and then with some slightly bigger (like mine). I'd be willing to lend my IHs/plenum to ya to do just that, but there would be the transition between my 36.xs to your heads' 35s to figure out (epoxy?).
That wouldn't work. My heads are neither 35mm, nor round, at that interface. We're not going to get crazy on the housings csa, but we will knock the injector boss way down, and enlarge the entry. Kevin's mono runner is a cool looking piece, and flows very well, but I'm not going that far.
As for the "Big Dogs" not flowing as well as Todd's, (assuming all else being equal in the test) there's got to be some turbulence being developed in their design that is creating some kind of standing wave(s) - effectively pinching off the air flow...would be my guess.
I think it has more to do with my valves, chamber, and short side radius, rather than any particular turbulence in Kevin's port. His heads flow very well.
Todd
Old 02-03-2010   #32
Pete, I read about it in his book, Sean Hyland also has a website.
http://www.seanhylandmotorsport.com/
http://www.seanhylandmotorsport.com/..._engines.shtml
1998 DOHC 4.6 with secondaries
http://www.karkraft.com/New%20Parts%201165.jpg
5.4 -GT/Cobra R heads
http://www.karkraft.com/Ford%20GT%20heads2.jpg
Twin Port Head
Dimensions (Intake)
Square Port 32mm x 40mm
Oval Port 36mm x 44mm 1999 & Later 4.6L Tumble Port (Intake)
50mm x 39mm 1998 & Later 5.4L Tumble Port (Intake)
59mm x 39mm
All DOHC Exhaust Ports
48mm x 25mm
Check Border's or Barnes and Noble for the book.
Old 02-05-2010   #33
Polo-1
rumor has it, Todd's heads and my intake flowed only 10 cfm less then just my heads alone.
Old 02-05-2010   #34
Where's the choke point? Is it throttle body or plenum volume?
Old 02-06-2010   #35
Polo-1
2 38mm balls fall all the way down into the heads.
TB is 2 64 mm blades plus over sized primary.
Old 02-06-2010   #36
Not sure how many of these apply to the DOHC cam engines, but..
http://www.wallaceracing.com/Calculators.htm
