#31 | |
#32 |
where do you get and how much are the replacements?
#33 |
Last pair I got was from a registry member. One off of Ebay
#34 |
![]() Join Date: Aug 2008
I bought two on ebay for $50. They came off an 18K Z. I gave one away to a reg member who needed one and the other one is rolling around in one of the kitchen drawers. I'll keep that one for myself. I'll probably need it one day.
#35 | |
![]() There is a black plastic sheet about 24 inches x 8 inches that sits under the radiator....which way does that fit ![]() There are two slots in it about 3 inches from each end. Not like I am highjacking this thread or anything ![]() I will go out now and test my secondary actuators for ya ![]() |
#36 |
![]() Join Date: Nov 2007
Are my posts invisible?
#37 |
Dynamite! Are you legally blonde?
![]() Last edited by rhipsher; 01-06-2010 at 11:51 PM. |
#38 |
#39 | |
![]() I am NOT ignoring you....this darn system is so slow tonight I can hardly stand it ![]() ![]() What you say as a solution I am doing all of that. I just got back from experimenting exactly as you suggested (after spending the last couple hours trying to dry out my cell phone) hot wiring a spare vacuum pump I have and using a long spare roll of vacuum line connected to each secondary. Do you want to hear how the ole experiment went ![]() Well....The actuators were first installed correctly for the experiment (they were backward before) with the short leg of the shaft "L" facing toward center of engine......(the short leg of the "L" was facing outward before and incorrectly causing the actuator shaft to be angled toward the outside of the engine toward the actuator)...... When I applied a vacuum to either actuator, the first motion of the "L" was toward the center of the engine a bit (toward the direction of the short leg of the "L"). Both actuators moved from that point smoothly pulling the secondary. Now.....32valveZ if I rotate both actuators back the "wrong way" like they were.....with the short leg of the shaft "L" facing outward and with the resulting greater angle of the shaft........the first motion was outward in the direction of the short leg of the "L" tending to make the angle of the shaft less and that side motion was greater than it was when they were installed correctly with the starting angle of the actuator shaft less. So....what you are saying 32valveZ is that since these actuator shafts started with a greater side motion when installed incorrectly there is prolly much greater fatigue of the rubber which is suppose to hold the vacuum. And now if one were to keep those secondary actuators (installed now correctly) the motion of the actuator shaft has now changed considerably and as such would not be reliable especially given the work to replace them involves removal of the plenum and other crapola ![]() ![]() Last edited by Dynomite; 01-07-2010 at 12:30 AM. |
#40 |
![]() very funny rhipsher ![]() I thought I was at the place here where I can ask stupid questions ![]() Damn cell phone in the washing machine made me feel like I should apply for some of those Obama social programs where the $%&*#$&% you are the more money you get ![]() When anyone uses the sign ![]() ![]() Last edited by Dynomite; 01-07-2010 at 01:04 AM. |
