Old 01-04-2010   #31
RHanselman
RHanselman's Avatar
Default Re: Who's modding their car this winter??
Originally Posted by Bob G View Post
It could be ,But we don't know the price all done & tuned?
Bob G
427 LT5
On a stock car it's less than $12k.
How about the price of a 427??
Ron Hanselman
Founding Member #80
CM Lifetime Member #1093
1991 #383 Twin Turbo
1993 #099 Ruby, Jeal 368 w/Snake Skinner body
1961 White with Red Int
RHanselman is offline   Reply With Quote
Old 01-04-2010   #32
Bob G
6000.00 For My short , But I started with a 402 so I had a good crank shaft
Bob G
427 LT5
Bob G is offline   Reply With Quote
Old 01-04-2010   #33
RHanselman
RHanselman's Avatar
Bob G
427 LT5
Bob,
So around $10k when you add the crank just for the short block.
So after you received the short you had to add long block assembly, head and plenum port work, maybe CAMs, plus engine removal and install from the car, plus tune, plus headers and some other odds and ends. Looks like another $8-10k to Finnish. Assuming you would start with a stock motor. Am I close?? That would be about $10k less than most LT5 guys would build you a 415 for a year or two ago. I think your got a great deal and it helps to have had a 402 to start with.
Who did your short block and did you use the closed deck liners?
The nice thing about the tubo system is you just drop your old exhaust and replace with the turbo system. It's a little more complex than that, you do have to add the turbo oil system and the wire harness but not much...
Cheers,
RH
Ron Hanselman
Founding Member #80
Old 01-04-2010   #34
Toyvet1
Well it was a good week. Last week I removed the stereo and shipped it to Dr Don. Was informed the amps were out of a Caddy. So they needed to be replaced, decide to use the amps out a a convertible that will give a little more power. The head unit couldnt be just repaired to stock so it was upgrade to play all types of CDs. With luck it will go back in this weekend. Havent a clue how Im going to get the reciever back in, dont know how I got it out. lol
Was able to replace the injectors, coils and two wheel bearings this weekend. While under the car noticed oil leaking out of the rear shocks, so they'll get sent out next.
Then its onto installing a five speed in the 1979............
Toyvet1 is offline   Reply With Quote
Old 01-07-2010   #35
Bob G
Hi Ron Yes It has the closed deck liners. I was the first, Tony @AES & I figured out how to do them He seams to thinkyou can go to a 4.155 bore but You would need head gaskets.You could get copper But I wouldn't run them on the street, Besides there is something about a 427 CORVETTE It kind of has a nice ring to it. I can't wait for BG I think Todd will have his closed deck 427 6 inch rod LT5 there Also
Bob G
427 LT5
Old 01-08-2010   #36
RHanselman
RHanselman's Avatar
Bob G
427 LT5
Bob,
You can run the stock gaskets with these? What's your bore and stroke?
Ron Hanselman
Founding Member #80
Old 01-08-2010   #37
Jagdpanzer
Jagdpanzer's Avatar
Bob,
What rod length did you go with in your 427 and where they Olivers?
Old 01-08-2010   #38
Bob G
The Bore is 4.125 & the stroke is 4.00 the Rod length is 5.85 the rods are the ones that Rippie used when he bilt the 402. I just can't remember what brand they are, Unless you open the chamber up in the heads you can't use a 6 inch rod unless you wan't 13 to 1 compression.
Ron isn't that car of yours a 368 with low compression? Or was I thinking
of something else ?
Bob G
427 LT5
Old 01-08-2010   #39
RHanselman
RHanselman's Avatar
It's 9:1 and 374 ci
I have an extra motor in Las Vegas and was thinking of a 9.5:1 closed deck 427...
Ron Hanselman
Founding Member #80
Old 01-08-2010   #40
Pete
Pete's Avatar
Originally Posted by RHanselman View Post
Bob,
Ron,you can run stock gasket up to 4.125 bore,.
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
