#31 | |
![]() Join Date: Feb 2009
![]() Rich
#32 |
![]() Join Date: May 2007
Rich, I did not intend to scare you. I might have missed the discussion where you confirmed that you could hear the noise from the water pump with the stethoscope. By the way, did that work well?
If you can't definitively assign the noise to one component, my offer to swap the idler pully with mine stands. That isn't too big a job. I have a spare alternator that we can try a swap if you need to. We will probably be having another Maintenance Day this weekend if Yun's front end parts come in. Jim |
#33 | |
The water pump was the only place I could here the noise with the stethoscope. I was able to place it on the bracket for the idler pulley and couldn't hear it. I was also able to get the probe directly on the alternator, power steering pump and a/c compressor. I'm 98% sure it's coming from the water pump. I am still going to pop the belt and check to see if I can generate the noise by hand. Rich
#34 |
Rich, That sounds pretty certain. While you have the coolant drained I guess you are going to replace the hoses. You may want to put in a new thermostat while the system is opened up.
If you are doing the hoses, you may want to come up and use the lift. Some of the lower hose connections are a pain to get to. Jim |
#35 | |
I am going to pull the belt one more time and see if I can feel what is making the noise. The lift sound good, but my other concern is driving any distance with this thing knocking like it is. Knocking noises of any kind can't be good. You think this is a job that can be done in one day? Rich
#36 |
![]() Join Date: Jul 2004
Just a FYI
Many moons ago I was In Norfolk VA drivng my ZR-1 back to NC and I lost all my accesories.. Belt was shreaded I was stranded on the side of the road. Come to find out the damn water pump pully had wobbled off the water pump shaft! I am serious I had the luck of having another ZR-1 owner living in the area and he towed my Car back down to NC for me about a week later while I hitched a ride on the greyhound!:-(**|= It could be a number of things going on with the pump, if the car has sat Ill bet your propeller has rust all over it its only a matter of time before it fails thats why our water pumps are our week link.
#37 | |
![]() Join Date: Aug 2006
Merry Christmas. |
#38 |
Rich, Probably a one day job.
I do have a convenient ZR-1 loaner program. ![]() |
#39 | |
![]() You just convinced me to put on a new water pump along with my new radiator and samco red hoses ![]() |
#40 | |
Jim Thanks, I'll try to troublehoot this week. Rich
