Old 06-23-2020   #31
grahambehan
Default Re: Eliminating the secondaries
And this makes me shake my head when I read stupid comments on the C8 forum about how DOHC motors need to spun like a sewing machine to make any power. 528chp from a 5.7L NA motor. And one designed 30years ago.
Graham, what cams did u use for this?
Power peak was at 7200 rpm.
Cam profiles were Lotus prototype.
Around 12mm lift, I think the duration was around 280 total.
I will dig out the info to confirm, don't have it with me at the shop.
Graham
grahambehan is offline   Reply With Quote
Old 06-23-2020   #32
Originally Posted by grahambehan View Post
Paul, et al
Engine made 528 hp
Ken owns the car that this engine was installed in.
I will put more info on the fb page, including video
Graham
Thanks for the clarifications, Graham. Much appreciated. And, if there are any dyno graphs available on that beast that you might have, I'll happily add them to my LT5 gen-III reference folder.
Paul.
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 06-29-2020   #33
Just to add...
With regard to coking on the valves, I should mention too that in addition to secondaries delete, the installation of an OIL CATCH CAN was a notable contributor to the reduction of valve coking.
90 #1202
Sans secondaries
