04-12-2017 | #31 |
Re: Speed at WOT ?
Im having this same issue and found this thread thru a googl e search. I have a 1991 ZR-1 with 68k miles. It has Borla exhaust so its possible it has 4.10s. With the tach reading 7000 rpm I'm at ~100mph in 3rd gear. I did the HVAC test and the tach is off ~300 rpm but it doesn't seem like 300 rpm would make a 20mph difference. I guess the only way to be sure is jack the rear up and count driveshaft revs?
Sent from my XT1080 using ZR-1 Net Registry mobile app
1991 ZR-1 #520 Arctic White/Gray |
04-12-2017 | #32 |
Re: Speed at WOT ?
Do you have a GPS? Compare that to your speedo.
04-12-2017 | #33 |
Re: Speed at WOT ?
Did that too. Speedo is accurate. Also, the shift light does come on when the tach reads 7k.
04-12-2017 | #34 |
Re: Speed at WOT ?
At a steady 70mph ctuise, what's ur rpm?
04-12-2017 | #35 |
Re: Speed at WOT ?
04-12-2017 | #36 |
Re: Speed at WOT ?
I have 4.10's and at 70 MPH I am about 1900 RPM.
04-14-2017 | #37 |
Re: Speed at WOT ?
The tach reads 1900. I checked using the HVAC readout and engine speed at 70mph is 1650.
What controls the shift light? The tach or the ecm? Sent from my XT1080 using ZR-1 Net Registry mobile app
