02-17-2021 | #31 |
Re: Hesitant on acceleration and nothing when you mash the throttle
if you need some pumps let me know. I have a couple of 2k miler pumps. went bigger to feed the LSV
02-18-2021 | #32 |
Just an update....When I was removing fuel pump assembly I saw that the bottom hose was disconnected ....It was basically laying on top of the fuel pump...
I did not remove the whole assembly....Got a good look at the whole assembly and saw no cracks.....Im hoping that's it...Tightened the clamp so now its on the pump tight.... Can't really drive it because we are getting hit with another snow storm.....Maybe I will attach fuel gauge again and check pressure.... |
02-18-2021 | #33 |
There you go, same thing happened to me. Should be good to go now.
02-24-2021 | #34 |
