11-15-2017 | #371 | |||
Re: TB removal and then some!!!
Thanks.....yes it is a good feeling to have everything working and performing the way it was designed to...... Yes....I have heard about the Hurst shifter install and thanks for the tip on sanding the powder coat off.....but this will be a WAZOO job when it can fit into a future WMD to be determined.....I have sat in quite a few members Z's with different shifters and yes....what a big difference from stock.....I know it will give the vehicle a whole new feel.....
Tom 1994 ZR-1 #009 "captured test fleet car" 1974 LS4 454 Vert 1982 L83 CFI...now a retired "dd"....Sold WAZOO Member |
12-20-2017 | #372 |
Finally got pics. Opened up the plenum runners and blended the sharp edges in the throttle body. Painted and added a few billet parts. Battery is dead again. Must have been a joint venture between Porsche and Gm on the electrical system. Right door close switch out again. Turns interior lights on when it shuts and off when it opens. Sent from my iPhone using ZR-1 Net Registry
1990 ZR1, 1987 Mustang GT (since new), 1973 DeTomaso Pantera, 1987 928S4 Passed on: 1984 930S (gray market), 1988 Mustang Coupe Trooper car(drag) |
12-29-2017 | #373 |
Had a new development occur today as I was headed to the WAZOO New Years luncheon. Got an early start and everything was going well......until I looked at the coolant temp on the highway.....I noticed the temp was at 159-160* @70mph and above....just hovering there....so I loop around to go back home.....not wanting to chance the over 2 hour drive each way with what may be a sticking thermostat.
Although the outside temp here is 19-21* and I did the TB coolant bypass months ago....I don't think that it have a 40* swing effect on the temp..... Now getting off the highway and back on local roads......the temp now goes up to operating range.....200* or higher when stopped for a light....but then still drops to 196* and lower to about 187* when moving....and through all of this the engine is running fine.....and the idle remains to be perfect with each stop.. Got back home fine.....now to figure out the problem......
Tom 1994 ZR-1 #009 "captured test fleet car" 1974 LS4 454 Vert 1982 L83 CFI...now a retired "dd"....Sold WAZOO Member Last edited by Roadster; 12-29-2017 at 01:50 PM. |
12-29-2017 | #374 |
12-29-2017 | #375 |
Probably the thermostat was stuck open, be thankful it wasn't stuck shut.
Rather have it run too cool then too hot... Replacing it should solve the problem? Other than this, Happy New Year Tom! |
12-29-2017 | #376 |
Not sure I would immediately believe the gages. Hook up a scanner, Tech1 or such or get a reading from the other sensor via the HVAC display. Even if the thermostat stuck fully open I would still expect to see correct operating temp once the engine is fully warmed up, even in cold ambient temps.
H
12-29-2017 | #377 | |||
12-29-2017 | #378 |
Tom,
About 4 years ago I installed a thermo stat with 3 1/8" holes drilled on the flange. It worked fine during the summer months resulting in about 10 degree drop. As soon as we hit cold weather, at highway speed, she was running at 140. Idling, temp would get up to 190 to 200. I would suspect you have a drilled thermostat also. |
12-29-2017 | #379 |
What deg thermostat do you have? Check Coolant Temp using digital readout #16 fan speed. Do NOT drill holes in thermostats.
It does take a long while to warm up all coolant in radiator. The thermostat can get confused during that initial warm up when radiator coolant is so cold. I do not see a problem. Happy New Year Sent from my iPhone using ZR-1 Net Registry
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 12-29-2017 at 02:42 PM. |
12-29-2017 | #380 |
I installed a Fluidyne several years ago trying to address overhating innsummer w AC on. We put in a 180d thermo w 4 holes. It did as u described. Temps dropped to 150 or so when cruising in 30d ambient. Finally, settled on 2 1/8” holes using 180d thermo. Works perfectly in warm or cold. Hot weather driving,
temps are easily kept within the 187- 198d range. Fans come on at 190 and 192. Cruising temps are below that. My cal for fans is set so temps are always in Closed Loop Learn range.
