Old 07-27-2011   #361
Default Re: LT5 Assembly Project
Polo-1.....With that new car you have nothing to fix or work on.....so you're just sitting around stirring up $hit now
Old 07-27-2011   #362
Kevin
Kevin's Avatar
Still waiting; race season means daily driver stuff goes to the back of the line at the shop
should have lied
Old 07-27-2011   #363
Polo-1
you know how to get a hold of me
It freak me out when I did the 380. I measured everything twice... It still was a little stuck at first. This is why I did the old plasta-gauge, triple checked. I used moly assembly lube on the bearings. The old black stuff..
Old 07-27-2011   #364
Polo-1
Still under warranty.... Got to wait...
I could sell you a set of new mains instead of asking questions
Old 07-28-2011   #365
Spend some time hovering around 7000+ and then we'll see if that LS7 can't drum up something to fix!
(Truth be known, I can't think of a better stable mate for the ZR-1 than a C6 Z06!)
P.
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 07-28-2011   #366
HIZNHRZ
Old 07-28-2011   #367
Block is done, pick it up tomorrow....stopped by the shop...rotates smooth as silk.
They told me I should use yamaha seal instead to seal the two block halves....
Old 07-28-2011   #368
I Assume he meant this stuff...
http://store.58cycle.com/product_p/yam%20sealant.htm
Old 07-28-2011   #369
Polo-1
Yes, I like the Three Bond 1104. It has been replaced by 1194 ( no lead). This was back in my 2 stroke day. This was the only stuff to seal up the no gasket cases. Yamabond is good stuff too. I was too chicken to use it on the upper to lower case halfs. Went with the old standby ( I hate that red stuff ) It dies hard brittle, the three bond/yamabond does not.
Old 07-30-2011   #370
Okay the suspense is killing me! What was the cause of the non rotation issue Lee?
