Old 06-19-2011   #351
Default Re: LT5 Assembly Project
I tried putting the outside bolts on, as suspected, it made no difference.
I then swapped bearings, no difference....I also checked the surface of upper and lower block, smooth and no issues.
I had the crank checked, fluxed and polished, no issues
This is weird
Old 06-19-2011   #352
Blue Flame Restorations
This is probably a silly question but did you mark the caps before dis-assembly and then place them exactly where they were before?
1990 ZR-1 #444 Convertible
1990 ZR-1 Black #966
1991 ZR-1 Quazar Blue #296
1957 Duntov SS Project
Old 06-19-2011   #353
LT-5 has a girdle, no caps they are part of the lower block
Old 06-19-2011   #354
Ok. See? I better stick to making them look pretty. LOL
Old 06-19-2011   #355
lbszr
lbszr's Avatar
This is weird
I'm not familiar with the recoated bearings, could they be too thick. Plastigage, or micing it as A26 mentions might verify where the problem is. Sounds like it would off to the machine shop, if all that checks out. But since it's the same crank and block, seems strange it won't fit all of sudden.
[FONT=Comic Sans MS][COLOR=red]"I wanna go fast!!"[/COLOR][/FONT]
[FONT=Comic Sans MS][COLOR=#ff0000]-- Ricky Bobby[/COLOR][/FONT]
Old 06-23-2011   #356
Dropped off the block bearings and crank at the machine shop, will let you know what they find.
Old 07-27-2011   #357
Kb7tif
Did the engine return from the doc yet?
1995 Convertible Supercharged Auto
1974 454 550hp (avatar car) On the blocks- -Scharger install !
1992-Zr-1 Sold.
Watson Headers
Ported Plenum, Housings
Random tech cats
Fidanza Flywheel
Chipped, Relocated Mat
Woods 165 stat
Borlas, Straights
1996 Lt4 Sold
1994 Lt1 Sold
2004 Z06 Sold
AKA** Illenema
Kb7tif is offline   Reply With Quote
Old 07-27-2011   #358
Still waiting; race season means daily driver stuff goes to the back of the line at the shop
Old 07-27-2011   #359
Polo-1
Lee did you have all the bolts run up ( main and girdle ) ?
I know when I did mine it was kind of locked. I had to work the crank front to rear (thrust). Then worked it normal rotation. After that it moves freely, with a high break away feel. The block definitely moves around. The liner are about .003 -.004 out,tapper without head or tq plate.
Old 07-27-2011   #360
Now you tell me, where the hell were you before!
