Old 08-18-2014   #321
Locobob
Default Re: Locobob's Interior Mod Thread
Originally Posted by ghlkal View Post
Looks great!
Did you ever find a source for the clips behind the radio bezel? I need one of those too ...
No I never found a source, I did find my other clip laying around but then lost it again when it popped off inside the console somewhere.
Robert
Old 08-18-2014   #322
Locobob
Robert,
this link has a lot of images of my install.. many at the end are the tablet install I now have..
Might swap back to the App Radio.. Still working it out on the Bench
https://plus.google.com/photos/10133...465?banner=pwa
Thanks Jeff, some of those may be helpful going forward. How come you have what looks like tweeters in both the sill panels and in the doors?
Robert
Old 08-18-2014   #323
Ah I actually have:
1" tweeter and 4" in the Sill
in the door is a 6.5" Mid bass
rear is currently a 6.5 woofer, although might swap those for 8s
Old 12-03-2014   #324
Locobob
Update:
Been driving the car a lot and am really happy with the way these projects turned out.
I still haven't gotten around to getting the upholstery work done on the console or seats.
I traced my stereo noise issue to the rear amps themselves, apparently it was just a coincidence that they went bad around the time I installed the new head unit. I am debating what to do with the amps/speakers still, for now I installed some 50w Bose amps out of a junkyard Infinity - $6 each. They work, and the sound is decent, but its not as good as it was with the 75w/100w combo I had before. Here are the amps, 100w on the left which I believe are intended to drive the woofers on a 99 vette, middle are 75w amps from a C4 vert - they are not labeled as such for some reason, far right is a 50w junkyard bose amp from an Infinity.
I placed the bluetooth mic on top of the rearview mirror, a few phone calls have confirmed that this is a really good place for it, voice comes through loud and clear.
The back-up cam works pretty well, sometimes the picture is a little fuzzy, I suspect I ran the video wire too close to a power wire somewhere.
The TPMS is awesome, here is what happens when you program the low pressure warning a little too low - on a very cold day it trips the low pressure warning.
I decided the steering wheel position was just not quite right for me. I took out the 1in spacer and replaced it with a .5in spacer. Doesn't sound like much of a change but it is noticeable and it feels more natural to me with the .5in spacer. On the negative side I lost just a bit of knee clearance with the swap.
Robert
Old 12-29-2014   #325
Robert,
Any progress on a design for your seats?
I am going to order a set in the next couple days.. trying to determine my red/black mix
Old 12-29-2014   #326
BigIke
Just went through all 33 pages, thanks for it!
What do you mean by loosing knee clearance? I'm 6'3" and was going to do the NRG/ D-shaped steering wheel to gain clearance... Might not if I will indeed loose room in that area.
Thanks
Jay
1991 White ZRJuan #1616
Mileage: 56K Sept-14 -- 113k May-18!!!
God Damn I Love This Car!
Old 12-31-2014   #327
Locobob
Robert,
No, I'm afraid it's on the back burner at the moment.
Robert
Old 12-31-2014   #328
Locobob
Thanks
Jay
I think you misunderstood Ike.... I lost a little knee clearance with the Momo wheel going from the 1.0 inch spacer to the .5 inch spacer - with either spacer width the aftermarket wheel is a net gain for knee clearance over the stock wheel. I am also 6'3" and with the aftermarket wheel I can actually drive with the wheel in the lower tilt position where as before I had it tilted 1 spot up.
Robert
Old 12-31-2014   #329
BigIke
GREAT!!!
I run with mine in the 1 notch up position as well, i want it in the lowest position, this post has solidified this mod! Thanks!
Old 08-14-2015   #330
BUMP IT UP..
Robert, how are you liking that steering wheel?
