Go Back   ZR-1 Net Registry Forums > C4 ZR-1 > C4 ZR-1 Member Rides
Old 10-12-2009   #21
Jagdpanzer
Jagdpanzer's Avatar
Default Re: '91 Red/Saddle #1147
Do you change out the rotor when using C5 calipers? What exactly do you need to change when installing C5 calipers on a 91Z? Do the C5 calipers offer better braking?
Brother Jeffvette has a good write up on his web site you might find useful.
http://www.pnwzr1.com/brake_install.htm
Old 10-12-2009   #22
So....with Jeffvette's brake adapters, I can install C5 calipers on my 1991 ZR1 as long as I have C5 rotors. I assume the C5 rotors are a bit thicker. The brake lines are the same? Does this apply to the rear brakes as well using C5 rear brake calipers (different adapters required)?
thanks
Old 10-12-2009   #23
Jagdpanzer
Jagdpanzer's Avatar
thanks
Do a search and you will find a number of previous posts about this topic here on the forum. Here is good one:
http://www.zr1netregistry.com/forum/...light=calipers
Old 10-12-2009   #24
I did a search but was searching with the wrong words
Thanks again.....that information is exactly what I was looking for. Jeffevette suggests C6 vice C5 calipers and I am assuming the brake adapter is the same but rotors may be different. I have to do some more checking.
Old 10-12-2009   #25
Jagdpanzer
Jagdpanzer's Avatar
I went with Jeff's brackets and C6 calipers and rotors:
Stock C6 and C5 rotors have the same width and mounting but appearence wise they look different.
Stock C5
Stock C6
Old 10-12-2009   #26
Great information
Where did you find the C6 calipers and rotors?
Old 10-12-2009   #27
Jagdpanzer
Jagdpanzer's Avatar
Great information
From a buddy in Texas who had just bought a brand new C6 that he immediately had upgraded to a big set of Wilwoods on all four corners. Had less than 500 miles on them when I received them. Still haven't figured out what to do with C6 rear calipers and rotors he also sent.
Last edited by Jagdpanzer; 10-12-2009 at 10:07 PM. Reason: Corrected the spelling of Wilwoods
