07-25-2009 | #21 | |
Re: Rough Idle/Hesitation/Backfire
07-25-2009 | #22 |
Stupid of me not to include this. When I scan my 90 at idle, in closed loop, the TPS does read .54v on my scanner. So jsut make your adjustment at idle and make sure you are up normal operating temp.
Sorry I type faster than I think..... Tom
07-25-2009 | #23 | |
As TT has said, loosen the TWO bolts on the side of the TPS and adjust with IGN ON so the DVM reads about .54v. Then tighten bolts and check WOT TPS signal. Should be at 4.5v or higher. If not, swap in new TPS. |
07-25-2009 | #24 |
When you say back fire, do you send detonation in the plenum or hear it at the tail pipe?
I never had this situation with fuel injected cars but way back when cars had carburators, cracked ign. wire would make gas vapor explode into the air filter housing. If it is coming through the tailpipe, its coming from uncombusted fuel detonating when it his catalytic converter. I very much doubt TPS, even if off a little, would do this. Lastly, I struggled with a similar symptom a few years ago. In my case it was hairline crack on one plug (very difficult to see). Cracked plug wire will behave in similar manner. |
07-25-2009 | #25 |
Here's where it will stand today:
I've got the TPS at the correct voltage. Operation seems smooth. I've changed all plugs other than the dreaded #8. I'll need a new spark plug socket to put it in...will pick one up today if they have them at Sears. All new injector coils. Took the car for a spin: some improvement but still not perfect. Then I changed my chip from a JVD chip to a DRM chip. Seemed a little better (or I may be imagining things). However, I feel that the JVD chip was better at the top end. Best I can tell, it is now running okay above 2K RMP. Any chance getting the last plug in could cure the problem? As for the backfire, it is hard to tell. I'm always in the car when it happens and I have some hearing loss that prevents me from knowing which direction sounds are coming from with any degree of accuracy. Later, I'll get my wife to rev the car and see if I can pinpoint the noise. Thanks for everyone's help! |
07-25-2009 | #26 | |
Also check all plugs and see if they appear uniform. I am sure we (with help from gurus) can sort this out. |
07-25-2009 | #27 |
I use a breaker bar with a short extension and a swivel. Just need it enough to "break" plug. Then I use a 3/8" fuel hose on top of spark plug to turn it the rest of the way and pull it out of hole. Works for putting it back in as well.
07-25-2009 | #28 |
Best plug advice I ever got and it works GREAT
Socket swivel 1" extension swivel Long extension when its loose push the plug wire in and it will grab the plug |
07-27-2009 | #29 |
Thanks for all the advise. I got plug #8 changed and I would say that the problem is about 98% cured. I can easily take off with no hesitation with either the DRM or JVD chip. I just get a little touch of hesitation if I'm rolling below 1200-1500 RPM (hard to tell exactly...at about 8 mph) and floor it. Maybe that's not a good idea anyway or maybe I needed new plugs too... Also, there is no more backfiring! Thanks again for all the help!
07-27-2009 | #30 | |
You might consider ('cause I am no guru) running a bottle of BG K-44 fuel system cleaner. You may have some deposit build up on intake valves. Now, some may chime in and talk about negative effect of this product I am not aware of so see general reaction first. At least in my case, after injector replacement, a bottle seems to have cleaned up intake and combustion chamber and took mine to 100%. |
