Old 07-05-2009   #21
Default Re: Clutch replacement questions
I typo'd I meant Mcleod Flywheel......can I use the Camaro clutch set up with the Mcleod Flywheel?
Old 07-05-2009   #22
no
you can use a camaro Disc, but you need the Corvette Pressure plate and throw-out bearing
Old 07-05-2009   #23
rhipsher
rhipsher's Avatar
Lee you can use a camaro disk with the ZR-1 clutch/preasure plate and new flywheel but you can't swap a camaro clutch in place of the stock clutch. There will be issues. And I know you don't want issues. So just use a camaro disk or an aftermarket one and your good to go.
Old 08-02-2009   #24
Well, I found 12mm 1.75 studs at ACE for $2.40 a piece, the trans is lined up on the studs, but still having a hell of a time getting it in the pilot bearing, only about an inch to get the trans flush with the bell housing.
Cannot wait to get the damn thing done.
Old 08-02-2009   #25
Kb7tif
Hey there. since there in only about an in to go can you maybe start a couple of bellhousing screws and bring the trans in that way, how i did mine, it didnt go so i was going to backed the trans out slid it forward again went right in.
Good luck.
1995 Convertible Supercharged Auto
1974 454 550hp (avatar car) On the blocks- -Scharger install !
1992-Zr-1 Sold.
Watson Headers
Ported Plenum, Housings
Random tech cats
Fidanza Flywheel
Chipped, Relocated Mat
Woods 165 stat
Borlas, Straights
1996 Lt4 Sold
1994 Lt1 Sold
2004 Z06 Sold
AKA** Illenema
Kb7tif is offline   Reply With Quote
Old 08-04-2009   #26
The boitch will just not go in, raised the trans, lowered it rocked it back and forth......any ideas?
Old 08-04-2009   #27
The boitch will just not go it, raised the trans, lowered it rocked it back and forth......any ideas?
you try doing it with the lights out??
Old 08-04-2009   #28
TIME FOR THE MURPHY HAMMER
Old 08-04-2009   #29
Not helping Jeffery .....not helping
PS: please also refrain from the "put some fur around it" comment
Old 08-04-2009   #30
QB93Z
QB93Z's Avatar
I had the same problem.
Fill the clutch resovoir and operate the clutch a few times. This will require getting the air out of the lines. Leave the clutch resovoir cap and bellows off while you pump the clutch pedal. After you cycle the clutch a few times the transmission will slide in.
Good Luck!
1990 Black ZR-1 - sold
1993 Quasar Blue ZR-1
1994 Competition Yellow ZR-1
1995 Dark Purple ZR-1
Maryland State Coordinator
