Old 06-02-2009   #21
secondchance
Default Re: Gasoline of choice
Originally Posted by Aurora40 View Post
Couldn't the race gas difference also be attributed to the fact that if someone is using race gas, they are also probably driving their car hard quite often? You probably don't have someone cruising 500 miles to Bowling Green on race gas, for example.
You got a point there.
Old 06-02-2009   #22
Jeffvette
It helps, but the issue is all the additives that are put in.
Old 06-02-2009   #23
RICHARD TILL
The sonoco 110 race gas that i run in the dragboat is leaded and 6 bucks per gallon. I can get 100 octane low lead at the local air strip for $3.38 per gallon. Both are blue in color. Can anyone tell me if the lead in the avaition gas would have any adverse affects on the ZR-1 and what they might be?
Old 06-02-2009   #24
Aurora40
Aurora40's Avatar
Lead would be bad for the oxygen sensors, and I believe it can coat/clog up the catalytic convertor.
