Old 02-25-2009   #21
Default Re: New Tune on car, problems
Originally Posted by kenthompson View Post
I agree, it got installed just as a check. Are you saying that is normal behavior?
I'm going to have to find my laptop that I used for recording on the diag connector so I can post voltages.
yes typical OEM O2 will swing lean to rich..
a Wideband would confirm for sure..
Old 02-25-2009   #22
O2 voltages are supposed to "swing" through a x-over point. So it is normal to see lean rich lean. The cat would be damaged otherwise. NB voltages are meaningless at WOT.
Old 02-26-2009   #23
kenthompson
kenthompson's Avatar
Changed the plugs tonight, (if I could figure out how to post pictures I would). Left bank appeared to be normal, gray-brown across ground strap and down center electrode. Right bank showed brown/gray across the underside of the ground strap (spark side) and the center electrode. The rest of it was black but dry. Number 5 had broken the porcelin (sp) on the center electrode and had basically shorted out.
Also changed out the O2 sensors (cheap insurance I thought).
Car runs a lot smoother now but issued a code 64 idling in my driveway.
At least we're getting down to less and less error codes!
Guess I'll pull the fuel pumps tomorrow night.
kenthompson is offline   Reply With Quote
Old 02-26-2009   #24
you will get it.. what is 64 again?
Old 02-27-2009   #25
kenthompson
Left side lean, I believe. Or right side lean.
Old 02-27-2009   #26
Rt side. May want to check injectors.
