Old 02-05-2009   #21
W i l l
Default Re: Clutch slave.
Rick,
Why not put a stainless insert in the old slave cylider like they do the C3 brakes? Anyone have a source for the plunger rubber???
Will
W i l l is offline   Reply With Quote
Old 02-06-2009   #22
LT5-Lee
Originally Posted by rhipsher View Post
Thats what I'm afraid of. If I made one at the shop It would be better than the ones that are on the market. I would find a piece of Titanium or 316 stainless laying around the shop. Make the body and the piston. Bleed port. And you would be able to unscrew the cylinder body from the ears like a Mag light and just replace the Oring seal when it wears out. Simple, easy, light weight/strong, Will never rust or tarnish.
Exactly, but you know as well as I do it would not be out of titanium. Maybe TIN coated but unsure of what brake fluid would do? Some 316 might be hard enough for the weak, 304 for better corrosion or how about some 4130 heat treated. Hell cast iron would work and use a steel or brass Holley jet for flow control.
An Unarmed Citizen is a Future Peasant.
Something BLOWbama & Hilary are trying to accomplish now at the UN with the "Global Small Arms Treaty"
LT5-Lee is offline   Reply With Quote
Old 02-06-2009   #23
LT5-Lee
Originally Posted by W i l l View Post
Rick,
Will
If you could find an old Wagner book, they list all their parts by size in the back index.
Old 02-06-2009   #24
rhipsher
rhipsher's Avatar
In due time my friends in due time. Parker Orings are some of the best http://www.parker.com/portal/site/PA...0048021dacRCRD
Old 02-06-2009   #25
scottfab
scottfab's Avatar
Even machining a new one from SS you'll still have the geometry problem of the pistong hitting the cylinder. This is a known problem from discussions involving Hib. (see archives of the net list)
I suppose a screw-in replacement would make it easier but....
a fix to the geometry would be better.
Scott
Old 02-06-2009   #26
rhipsher
rhipsher's Avatar
I guess I'm not quite sure what you mean by the piston hitting the cylinder. Do you mean the piston rubbing the inside of the cylinder or the rod lining up with the clutch fork? Or do you mean the piston is to sloppy of a fit inside the cylinder on the ones we buy? All of those are easy fixes if thats the case. This time I ended up with a cast iron slave. If this one fails prematurely then you can bet I'll design and make a custom one for my Z and if it holds up for at least three monthes with no problems then I will become a supporting vender and make them for you guys. Could be good for some extra beer money.
Old 02-06-2009   #27
LT5-Lee
For starters, checkout the "Common Issues" (#21,#25 & #26) area off the main page if you haven't read it all yet? Then there are more problems somewhere about bad newly manufactured replacements, I think from TRW?:-(**|=
Old 02-06-2009   #28
LT5-Lee
Then checkout "GM Clutch Hydraulic System Actuator" Under ZR-1 Trouble shooting section.
It has some pics and another link for even more great news for a slave cylinder.
Old 02-07-2009   #29
I remember the talk I had with Bill B via e-mail back in 05. He had mentioned there was also a geometry issue with the position of the M/C for the system. He found that the spacer GM used is not creating level travel of the M/C's piston, thus wearing the seal because it travels thru an arch rather than a dead flat line. He was considering the issue and what angle to remake the spacer to correct the OEM spacer's error.
In his opinion, the original spacer is just a degree or two off. He said that they didn't account for the fire wall being angled at the mounting point.
