06-09-2009 | #21 | |
Re: carter200's CNC machining is............
Thanks. |
06-09-2009 | #22 |
One major concern I have over supension mod is that, based on what I understand, changes in spring rate and/or roll bar can result in under steer/over steer characteristic.
Will you be testing and tweaking? |
06-09-2009 | #23 |
probably tweaking, I need to finish my poly bushing install and get the car aligned.. then I will see how well it does
06-09-2009 | #24 |
06-09-2009 | #25 |
will do.. keep in mind.. it is a slow going process with me
06-17-2009 | #26 |
Forgot to post some pics of the air filter bolts that Carter made - hope this works
06-17-2009 | #27 |
Very nice Bob! And Carter!
1991 #1516 Black/Black davidmkelly.com "Speed is often confused with insight." - Johan Cruijff |
06-17-2009 | #28 |
Thanks Bob and DaveK Bob, you gonna line em up or let em end up where they will? Either way they look nice. Thanks again
06-18-2009 | #29 |
how is the ride in comparison to before
I went with 400 front, and 275 back and the ride is OK, but I think the F1 supercars are the "problem" biggest thing I ran into is lowering the car too much. not good. I think I was bottoming out the shocks as I busted a fx3 controller I'd like to someday upgrade to a better shock and maybe lose the fx3. more hassle than it's worth to me. nice setup!! that's a great way to go as coil overs are expensive and you really engineered a bargain conversion FYI, DRM grooves the shocks pretty reasonable for the snap ring. a local machine shop quoted me 200 and DRM was 15 per shock as I remember (call randy) as for tuning, it's hard to "out engineer" the Gm engineers and the stock suspension is actually a pretty good compromize for street driving, but the coil overs definely help there is a bit of hassle getting them on there and setup, and because I'm so lazy I wouldn't have done it again knowing what I do now, but I mostly didn't like the expense and the harsh ride. there is no doubt the car is "glued down" better and much more stable at speed around corners. my c5 has coil overs, but rides like a cadillac in comparison alot of that is the EMTs though, when I bolt on my "race tires" with the a molds, ride is much better.
06-18-2009 | #30 |
Ron,
How low did you go? I have not noticed if it bottoms out, but the stance it very close to what my 89 was.. it seems much better.. as for the ride, I have not driven enough to say how it really is.. I have one more component to swap, then get an alignment.. Not sure i will get the new parts on this weekend but I am hoping to
