Old 07-07-2009   #21
Polo-1
Default Re: A few parts for my next engine
Originally Posted by tpepmeie View Post
Block is in Chicago Crank is getting ground down, also waiting pistons for final balancing.
Todd
Stock crank ground down to 2.00 rod for 3.75 stroke ? Mini stroker ?
Block in Chicago? home of the big bores????
What is your final cube's going to be?
Old 07-11-2009   #22
tpepmeie
Heads are nearly final, just need to adjust the velocity a bit at the housing interface and do some higher speed airflow tests. It is really trick how he shaped the port at the entry to cope with that awkward angle.
Final chamber volume ends up at 49cc's.
Pistons are on order now.
Old 07-11-2009   #23
tpepmeie
2.00 in. big end dia/6.0 in rods / 4.0 in. stroke. 427 ci.
Old 07-11-2009   #24
2.00 rod / 4.0 in. stroke. 427 ci.
Nice ratio.
Frank Urbo.
NCM Lifetime member # 982
Registry Founding # 237
Old 07-11-2009   #25
Polo-1
427 NICE
Old 07-11-2009   #26
Great work Todd.
One thing comes to mind reading all the posts. Remember all the bashing about how long it took to get a stroker built? Now that you guys are doing your own and encountering the same type of delays, it put it into proper perspective.
BTW, I am going to have full siamesed plenum gaskets made that are oversized on the outside shape (to cover the welded up areas, and undersized on the inside port area, so that they can be trimmed to fit each individual engine since the port configurations vary.
Old 09-03-2009   #27
tpepmeie
Some new eye candy. Custom CP pistons arrived.
Unfortunately, these were ordered without the valve reliefs -- a mistake by the builder . We've ordered a second lot with the correct valve reliefs. I also took the opportunity to make a few other tweaks to the design.
These will be for sale soon. Even w/o valve reliefs, they will handle some moderate cams.
Todd
Old 09-03-2009   #28
tf95ZR1
tf95ZR1's Avatar
Very nice project.
What will your compression be?
Old 09-03-2009   #29
jonszr1
jonszr1's Avatar
todd who is doing your porting?
Old 09-04-2009   #30
tpepmeie
Originally Posted by tf95ZR1 View Post
Very nice project.
12.0 to 1.
