Old 01-21-2010   #21
Default Re: Coil Over Installation
that is the front piece yes
the rear you need:
flip trailing arm bolts and grind down the head part way
move the top of the shock forward 1/2"
to do that you either weld and drill and new hole in the plate or 2 holes in the frame.
you also need to open the frame to allow room for the FX3 gear assembly to clear the frame too
Thanks Jeff! Your keeping the FX-3 as well right?
Old 01-21-2010   #22
Absolutely!!
Old 01-21-2010   #23
carter200
carter200's Avatar
Just talked to Ted on the phone. Looks like it's go time
95 ZR-1
BLK/Gry
#392
LT5 Reg# 868 *RIP*
ZR1NET Founding Mem #155
Old 01-21-2010   #24
for front and rear?
Old 01-23-2010   #25
for front and rear?
Wacha doing Carter?
Old 01-24-2010   #26
carter200
carter200's Avatar
Wacha doing Carter?
I don't machine and tell I'll leave the details to Ted to tell, if he wants.
95 ZR-1
BLK/Gry
#392
LT5 Reg# 868 *RIP*
Old 01-24-2010   #27
Demps
Demps's Avatar
Carter, class act! We're trying to make some minimally invasive ways to mount coil overs. Ted
Old 01-24-2010   #28
carter200
carter200's Avatar
Thanks Ted. I always leave the ball in the customers court. Do not want to steal anyones thunder. Mums the word
95 ZR-1
BLK/Gry
#392
LT5 Reg# 868 *RIP*
Old 01-27-2010   #29
RHanselman
RHanselman's Avatar
So which car is getting the coil's?
The Black car or the Dark Red car?
Cheers,
Rat
Ron Hanselman
Founding Member #80
CM Lifetime Member #1093
1991 #383 Twin Turbo
1993 #099 Ruby, Jeal 368 w/Snake Skinner body
1961 White with Red Int
RHanselman is offline   Reply With Quote
Old 01-27-2010   #30
Demps
Demps's Avatar
Black car...I hope.
Ran across Hairball?
