10-10-2008 | #21 | |
Re: Replacing coolant...
10-10-2008 | #22 |
yes , dot use tap water if you can help it . but its no bigge draining it .just ake your time filling it and pull the hose going to the t body and it will fill 95 percent . then just fill the overflow all the way up .start the car warm it up . ,have the heater on high(90) then shut it off . come back in a couple of hours and you will notice that the overflow tank has gone down a bunch . now you are ready to go. fill the over flow to mark if need be
10-10-2008 | #23 |
Jeff, the white powder is the minerals in most tap water. If you heat a pot on the stove & it boils off all the water you usually have a white powder, the disolved minerals that are common in tap water...well water can be worse!
Have no fear to drain & refill an LT5....it's a snap and no burping like the L98/1/4's. Just empty the system using the pet **** on the rad. refill w/tap water to full and run car till T-stat opens, idle a bit after opening of stst and shut down and drain at ****. Repeat till run off comes clear. Drain and use steam distilled H2O + coolant and fill upper tank tillfull. Start motor w/tank open and continue to fill to bottom of neck, cap it and pour rest into overflow to the hot mark. Run till stat opens(upper hose hot), turn heater on, check overflow & add if needed. Shut down and come back when cooled off and check level in top tank and at overflow, add as needed. No burping, we are self-burping. Tom Oh, you will eventually get all the powder out if you are religious about coolant dumps every two yrs....Do Not use any flush chemicals!
