![]() Join Date: Mar 2007
Patiently I spent all winter porting my intake, mostly with a Dremel which is akin to digging your way out of prison with a spoon, and now I am waiting for the first Byron test and tune so that I can best my 12.54 from last year.
So whats the ETA on a track day here in Il? Pete I know you saw my handy work on the plenum and are probably running alittle scared at this point, but I promise not to spank you too bad(this is called baiting ![]() Dominic, Hans, Don, Jeff, PAul, Al, ..........anyone interested in going this month? Anyhow, fired up and ready to see how it runs. LGAFF 92 ZR1 #234 |
Lgaff,
This month means this coming weekend. Next weekend is Memorial Day. Might want to shoot for the 31st. |
#3 | |
![]() Join Date: Jul 2007
Jeff-This month...no, maybe October...I need to at least DRIVE my car a bit first.
Drive it a bit to the track, and then drive it a bit down the 1/4 mile. ![]() LGAFF 91 ZR1 #234 |
Looks like a few vettes are going on the 17th.
LGAFF 92 ZR1 #234 |
#6 | |
![]() Join Date: Nov 2007
I see y'all go Byron to run. Is the Route 66 track too expensive or ???? It is a lot closer than IN (south of Joliet on - IL 53 (old US-66)). The reason I mention it is b/c they have scheduled "Test and Tune" days on a semi-regular basis during the summer months. From what I understand, it is a "come one, come all" format. I have a good friend that works there and I can get the particulars, if that should interest anyone. (Forgive my ignorance re the "66" track, as I've never looked into running there up to now. ![]() P. Last edited by Paul Workman; 05-14-2008 at 07:54 AM. |
#7 | |
Also Byron is in IL out by Rockford, Paul, you are thinking of US 41.. in IN
![]() Join Date: Jan 2008
LGAFF,
I am pretty much shot for this month with having gone to B.G. and now with memorial day weekend coming - I have to go to a wedding in St. Louis that weekend. so kiss the month of May good by. However - I had a Great time at the Drag's in B.G. ![]() Don Yoakem 91- #267 Dark Red Met. |
#9 |
Planning on a Byron run tomorrow if the weather is nice....ran the car today, peeked between the runners, secondaries are opening, etc
Only issue is a high idle, no vac leaks, appears throttle cable or throttle bodies are sticking alittle and not letting the blades close all the way. A small tap and it goes back down to 750rpm. LGAFF 92 ZR1 #234 |
#10 | |
