Old 04-04-2008   #21
Default Re: trouble with my zr1
Originally Posted by zr1con
You guys just saved me a lot of time, i found it and it had popped,the pump started up but didnt stop,put my finger on the pump and it stopped.
At that time i thought **** the plenum must of but for once i had some luck ,the hose from the pump towards the plenum was leaking,i replaced it with some silicon hose i have for another car and the pump stopped for around 5 min than started for a few seconds. Thats the way it should be right?
Its raining so i have to wait with the test drive but i think this should take care of my problems .
I think the hose was the first problem than the pump has been on for a long time and the fuse popped.
Yes I think you found your trouble. The hose must have been holed first and then the fuse popped from over heating caused by the pump running too long. Strickly speaking the pump should run to prime up the system and then be silent for the duration of time that the motor is left running....but in the real world a brief burst every long while is a servicable system. Ideally it should only run at start up and then never again...if there are absolutely no vacuum leaks, not even the smallest of leaks. You should be okay.
Old 04-04-2008   #22
Tyler Townsley
Can anyone do a carfax on this one?
Tyler
Old 04-06-2008   #23
zr1con
Went for a test drive today ,no error codes and engine was running smooth all the way to 7.5 rpm, i just love that power and sound
Its something about this car i cant stop smiling when i drive it, i must look stupid but its just a feeling i get.
Do you guys know if there is any stronger frame/chassi in the original convertible verses the hatchback type??
Got the service manual today, man that thing is huge i have reading material for a year.
zr1con is offline   Reply With Quote
Old 04-06-2008   #24
32valvZ
32valvZ's Avatar
Dont worry, theres a bunch of us over here in the U.S. with that same stupid smerck on our faces everytime we drive ours too!!
