Old 01-17-2009   #21
bobbyhi
bobbyhi's Avatar
Default Re: How to calibrate the tac??
The issue with our tach, like all the other electronic tachs since at least 84 is that the damn thing is slow to react. Get a shift light.
On my '90 the tach is also off by about 10%. I was thinking of just putting on a tach with the shift light and not worry about fixing the console tach.
Bob Anderson
1990 #2405 White/Gray
Haibeck chip,4:09 gears,Power Effects Exhaust,5 spoke chrome,C5 brakes,49th Street rockers,K&N,Hurst,Headers,Upper & lower ported
Minnesota State Director
Founding Member #19
Old 01-18-2009   #22
Jarek5_7
guys do you know how the console tach is connected?
I dont think it reads the impulses from ecm because ECM reads good rpms. I checked it today with aldl cavble and datamaster. adn the tach shows almost exacly the twice rpm as shown on datamaster.
so I thought maybe tach is connected to coil or coils and there is somewhere a short and tach reads impulses from two coils instead of one or something like that.
Jarek5_7 is offline   Reply With Quote
Old 01-18-2009   #23
WVZR-1
Rest assured that the error you're seeing is from "failed/failing" resistors/capacitors on the instrument cluster "main-board". Your confirmation is the "correct" output from the ALDL with your software.
Your location certainly doesn't offer a very economical solution to your situation. If you've an acquaintance here in the US you could arrange the repair from a facility here.
The error you see I'm sure has increased over time. Minimal error when you first noticed or suspected it and it WILL become worse over time.
Old 01-19-2009   #24
Jarek5_7
I think I`ll get aftermarket tach and connect it on the electronic ingnition diagnostic terminal F, book says its instrument cluster tach input so then I will see if its the problem with instrument cluster or some wiring.
1991 zr1 convertible ;)
