Old 03-13-2007   #21
8388
Default Re: Lifter Tick??
Listening to your video, it seems to flutter a little while raising the rpms. It could just be my pc, but make sure you don't have an exhaust leak. When doing your spark plugs make sure to torque them down properly. You can have a slight leak there. If you don't have a stethescope, a vacumm cleaner hose, can also help locate the source.
8388 is offline   Reply With Quote
Old 03-13-2007   #22
RiceEatingZR1
RiceEatingZR1's Avatar
Originally Posted by jonszr1
be very carefull when gapping them as that little tiny tip breaks very easy ( found out the hard way) I set my gap @45 with a gap ring . you also need the wire gapper for bending the strap. I found that the gap out of the box was between 60 -70 thou and thats too big . Ps you have a very nice engine compartment . did you get her pcd?
Yeah I had Marc Haibeck refinish it and do the injectors at the same time. he did a great job I would recommend him to anyone.
How hard it is to get the plenum off to change out the wires? and Im guessing Ill have to get new gaskets for that as well right. Also can I get new Coil Packs (if needed) from napa? any one know a part number?
-Shaun
1991 Charcoal Metallic ZR1 #730
[URL="http://www.cardomain.com/ride/2649606"]http://www.cardomain.com/ride/2649606[/URL]
[URL="http://community.webshots.com/user/shaun91zr1"][/URL]
[IMG]http://img.photobucket.com/albums/v211/RiceEatingZR1/Forum%20Sig/Sig1.gif[/IMG]
RiceEatingZR1 is offline   Reply With Quote
Old 03-13-2007   #23
jonszr1
jonszr1's Avatar
you can get the gaskets from kurt white white racing. its easy mark sell a cd on pulling the plenum if your a little unsure its a good buy just to have for reference. coil packs can be got from kurt also
