Old 08-05-2007   #21
janozr1
Default Re: full power problem
OK, I done , my plenum is off , now everything seems to me just normall,
no any leaks , inlet valve actuators are well , how can I test inlet soleonid
valve now ???
jano
janozr1 is offline   Reply With Quote
Old 08-05-2007   #22
janozr1
BINGO , both sec. actuators are leaking , I disconeted and conect them (bypass) direct to vaccum pump which is running nonstop.
SOOOO , thanke you all for this help via forum, I m proud mechanical now .
Last info i need is where is best way to buy them , including with shipping oversea ....Kurt or....
regards,jano
Old 08-05-2007   #23
gbrtng
gbrtng's Avatar
regards,jano
Try pushing a diaphram in and hold a finger over the vacuum port
to see if the diaphrams REALLY are leaking. It is highly unlikely that both
actuators are leaking. You might find that a vacuum line is leaking
or the vacuum pump has failed instead. Good luck !
Old 08-05-2007   #24
janozr1
gbrtng , yes Im sure I check them well , Im just looking where to buy them...
