#21 |
![]() Join Date: Aug 2012
Looks like you are all set and looking forward to Carlisle. I have the Powerstop drilled and slotted rotors and they are nice.
#22 | |
![]() Join Date: Jul 2017
Good to hear, it will be nice to not have to worry about the brakes for a while, and have them looking good on top of that. I punched out the brake dust guards from my wheels as well (finally) so I'll actually be able to see everything. Of course now that the wheels are off for a bit, I should look into wheel refinish, because, you know, while I'm in there ...
1990 Black/Black ZR-1 #1155 1993 White/Red coupe (Regrettably sold) ![]() |
#23 |
Got some stuff today.
#24 |
Powder coating done.
#25 |
Operation scrub the corners has begun. Made some quick progress, and my shock is yellow again (mostly). Forgot to get a before pic, but will on the next corners. Expecting lots of elbow grease to get it where I want. ABS sensor came right out, got lucky there.
#26 |
Looking to get a brake bleeder kit of some kind for when I'm ready to put everything back together.
If anyone has recommendations, would be appreciated.
#27 |
![]() Join Date: Jan 2010
Dan
Get some Speed Bleeders, they make bleeding brakes a one man job. There's nothing worse than having your Bride help you bleed brakes.... Ask me how I know... They're bleed screws with a built in check valve. Summit probably has them. |
#28 | |
![]() Join Date: May 2010
100% agree. Speed bleeders on all the cars and Harleys. [emoji1360]🤙🏼 Total lifesaver!! Sent from my iPhone using ZR-1 Net Registry
Craig "ZR-1 NO KA 'OI" "ZR-1 ICHIBAN" 1995 #228 Black/Black with Dunn Heads ZR-1 owner since September 2003 ZR-1 Net Registry Founding Member #0074 NCM Lifetime Member #2048 ![]() |
#29 |
Speed bleeders it is. Thanks guys!
#30 |
Refurbished calipers and brackets on the way. Also got DRM SS braided brake lines coming. Like a kid waiting for christmas.
