Old 07-19-2024   #21
scorp508
Question Re: Secondary fuel pump dead?
Originally Posted by Subfixer View Post
I got the high flow pumps as I'm pushing around 560 crank hp.
Subfixer, did you need to do any modifications to get these pumps to fit into the sending unit? I received the kit from Lingenfetler and all ways going smoothly until trying to slide the new pumps into the frame.
My stock pumps measure ~36.75mm in width.
The Walbro GSS340 pumps I received from Lingenfelter in the high flow kit measure ~39.18mm in width and will NOT push into the holder.
https://walbrofuelpumps.com/255lph-w...pump.html.html
I don't see how these are going to go in without cutting a slit in the side of the frame for each pump, then praying to the zip-tie gods it holds together.
Old 07-19-2024   #22
Subfixer
Subfixer's Avatar
Default Re: Secondary fuel pump dead?
Yes. I split the holder down one side. Secured with tie wraps.
Sent from my Pixel 4a (5G) using ZR-1 Net Registry mobile app
2018 Audi RS5, 2.9 V6 Twin Turbo, Auto, Black, Black
