Old 03-03-2022   #21
lfalzarano
Default Re: Need your ideas - LT5 won?t turnover
A bent clutch fork can also cause a low pedal disengagement. Bent and broken clutch forks are an infrequent but known occurrence in the ZR-1.
Lets see an apostrophe '', and a Question mark???
Showed up fine from my keyboard
I'm using an iPhone and sometimes W10 laptop.
Old 03-03-2022   #22
lfalzarano
Originally Posted by tf95ZR1 View Post
Keeping it simple (KISS) are they depressing
the clutch pedal all the way to the floor?
Yes, and it was still hard to shift gears.
Old 03-03-2022   #23
aafc
aafc's Avatar
I don't know if this helps you, but it got me home.
Before I changed from the zf gear box to an auto, I had no start while out
shopping. Would not turn over engine, Set park brake, car in neutral,
key to on position took a jumper wire and connected it to power then
touch to the purple wire direct to starter.
( car in neutral! when you do this )
Got car car started and drove home. As it turned out the
clutch safety switch had an open in the ckt.
my no start was not because of clutch repair. So not sure if this helps.
1990 white/black #2546
one of a few 4l8OE EQ R-1's
aafc is offline   Reply With Quote
Old 03-03-2022   #24
Originally Posted by Young1 View Post
It?s not necessary to move to remove the ECU, you just remove it from its bracket and flip it over out of the way. If they took all the clips out of the back of the eco and put them back in incorrectly that could be your problem. Again not rocket science.
Agree. But, too if they DID disconnect the ECU, there's the chance to bend one of the pins. But, an OBD-1 scanner would probably(?) pick up on that pretty quick. But, yeah. I can't imagine how changing the clutch hydraulics and hardware would affect anything to do with starting - ordinarily (that is).
I've come to hate taking my cars to anyone except a known GOOD mechanic...and they're darn few, it seems. And, DEALERS (aka parts swappers) especially! Like: when was the last time they worked on a ZR-1??? Was the mechanic even BORN when the car came out???
Old 03-04-2022   #25
lfalzarano
Thanks to everyone. IT IS FIXED! A second mechanic found the Clutch safety switch was defective AND REPLACED IT. yeah!
