01-10-2022 | #21 |
Re: LT5 Refresh
My second bargain basement purchase came today.
This is a complete rebuilt LT5 from 90 # 2793. It has already been converted to secondary delete. It does need final assembly of some parts, but it's all there. Came with wiring harness, ECU reprogrammed by Marc, Black label ZF6, Bell housing, Thermostat housing, water pipes, etc..... Only missing the AC compressor. All that for 1/2 the price of a crate LT5. Can anyone identify the headers on this engine? They are not originals that I can tell. After taking a hard look at the first LT5 #0116, looks like it is going to be completely disassembled and redone. I'll tackle that after I finish the assembly of #2793.
1992 ZR1 #442, 2 tops, White, White, Haibeck 415, 3.90 gear, Coilovers 2018 Audi RS5, 2.9 V6 Twin Turbo, Auto, Black, Black 2021 Audi Q3, 2.0T, 8 spd Tiptronic, Navarro Blue metallic, Pearl Beige |
01-10-2022 | #22 |
Re: LT5 Refresh
Damn! Looks like a lot of fun.
1990 Black/Black ZR-1 #1155 1993 White/Red coupe (Regrettably sold) |
01-11-2022 | #23 |
Re: LT5 Refresh
Theres no air injection on the headers so they arent stock, although they do look like stock 1993-1995 manifolds with bolt on cats.
Need more detailed pics to be sure. Crabs
TomC '90ZR1 #792 Honorary Pirate [B]If it ain't FUN, you're doing something terribly WRONG. [/B] Last edited by tccrab; 01-11-2022 at 01:37 AM. |
01-13-2022 | #24 |
Re: LT5 Refresh
Here's a couple of better header pics. No provision for O2 sensors.
01-19-2022 | #25 |
Cam Cover Bolts
Ok guys, what's the trick to get the Cam Cover bolts out?
Nothing moving with a 30" breaker bar. I don't want to strip out the bolt heads. No movement with one of those impact drivers (the one you hit with a hammer). Engine is on a stand.
01-19-2022 | #26 |
Re: LT5 Refresh
If you use an impact gun, you can center yourself directly over the bolt and focus on creating downward force while the impact gun hammers the bolts loose. Marc was not opposed to this method when I discussed it with him. I have a few. One has 300 ft lbs breakaway torque and the other is 1200.
01-19-2022 | #27 |
Re: LT5 Refresh
The trick is a good brand torx bit (buy a few just in case) that fits snug and that won?t twist or crack. Then a good impact gun no extension using the same technique 1991 Corvette ZR-1 mentioned above.
I have broken a few my first time at it when I did it by hand and it sucks! Good luck Sent from my iPhone using ZR-1 Net Registry |
01-19-2022 | #28 | |
Re: LT5 Refresh
01-20-2022 | #29 |
Re: Cam Cover Bolts
That's method I used all cam out with no problems. The key is clean out the hole in the bolt and use a good torx bit with sharp points
01-20-2022 | #30 |
Re: Cam Cover Bolts
Yes, I agree. The hammer impact is the perfect tool for jobs like this. The shock helps to loosen the bolt, the angle of the tool is easy to maintain and the hammer impact drives the too to the bottom of the torx hole at the same time the torque is applied. One of my favorite tools for several decades now. Actually gave each of my sons one for Christmas this year.
