Old 10-18-2021   #21
moesvette
moesvette's Avatar
Default Re: Antenna Bezel Replacement
After having replaced the mast (had to remove antenna motor to remove broken plastic pieces), I decided to try using the standard C4 bezel. It works okay, but it sits a little high compared to the proper bezel. May try milling it down some to get a better fit. All in all, it isn't terrible.
http://www.zr1.net/forum/attachment....1&d=1634563178
1990 Red/Tan Mark Haibeck Chip/B & B
moesvette is offline   Reply With Quote
Old 10-18-2021   #22
Looks fine from here--I would just leave it and forget it. As I recall, pulling and installing the antenna is a pain. Unless you are an incredible perfectionist and are afraid an NCRS judge might notice, I would just enjoy your Z!--Bob
