#21 | |
![]() Join Date: Sep 2018
I was a C2 guy for 17 years prior to my ZR-1 purchase, although definitely NOT numbers matching.
1992 ZR1 #442, 2 tops, White, White, Haibeck 415, 3.90 gear, Coilovers 2018 Audi RS5, 2.9 V6 Twin Turbo, Auto, Black, Black 2021 Audi Q3, 2.0T, 8 spd Tiptronic, Navarro Blue metallic, Pearl Beige |
#22 |
![]() Join Date: Aug 2018
very tempting as its a very inexpensive part but i've told myself that I will not convert to LED.... I do have a bulb out up there
1994 #353 "Bluey" |
#23 | |
I had the LED ready for install in about 30 minutes after sawing off the mounting tabs and clearancing the back of the LED plastic so it could seat in between the light shells and lense. Jagdpanzer?s looks brighter than mine but mine ended up looking just like the factory lights. The big benefit of less amp draw was worth the time to fit it. Edit: As I sit here after this initial post it hit me. Maybe Jag?s looks as bright as it does because he tied both power wires into the factory power feed side. I have Zevo red LED bulbs showing up this week for the four bumper lights. If they end up brighter than the CHMSL I may go back in there And try tying both wires into the power side as my OCD would bug me if the brightness is not similar across all brake lights. Last edited by 1991 Corvette ZR-1; 01-12-2022 at 08:17 PM. |
#24 |
I don't think mine ended up any brighter that the original, but there's a more complete look to it vs 4 bulbs.
My tail lights are LED also.
#25 |
Did your lenses come out easy? Mine are ON there. Removed the screws and it is like they are still in. Sadly, I think this weekend I will be doing the old 84 to 90 bulb change method to remove the whole housings. I can?t believe how stuck on there the lenses are.
#26 |
Those lens gaskets can really get stuck. I just took my time with plastic tools to get mine off.
#27 |
![]() Join Date: Jul 2020
Why not just install 891 / G4 LED bulbs replacements in the original sockets?
#28 |
![]() Join Date: Apr 2007
#29 |
#30 |
There are a couple sources for red LED 891/G4 bulbs. But you can also use white LED. Someone would have to try a few out to determine best choice. They're not all the same size even though it's a standard 2-pin base.
