Old 03-10-2021   #21
Default Re: Tires - Best Driving Tires
Originally Posted by JThomas View Post
I rarely speak negative, but if there was one tire I would take off the list would be Sumitomo. They are less expensive, but NOT a performance tire, and I don't care if you weekend drive it to the grocery store or enjoy a spirited drive from time to time, you and your car deserve better.
And I am in for four, Joe! Had Sumis on the '95 and could never get them to balance right. Went to a tire shop in in Bowling Green in 2014 or 2015 and the tech there, using a Road Force balancer, concluded that all the tires were very near the limits for being out of spec and in any case needed to be spun on the rims 180 degrees. One of the tires was so far out of manufacturer's specs that it could not be balanced at all. He was able to get them close enough so that I could hardly detect a vibration, but soon thereafter I switched to Michelin Pilot SPorts. Costco had no trouble balancing them even without a Road Force. They were great tires. --Bob
Old 03-10-2021   #22
JSad
JSad's Avatar
I run the Nitto 555s and they handle fine for me and don't flat spot but I use mine as an almost daily driver so it doesn't set for long. That said, if I could slightly hijack this thread, I live in Oklahoma and drive mine year round. What are the thoughts on driving summer tires at low temps, say below 45 degrees? Should I move to the Motivos?
JSad is offline   Reply With Quote
Old 03-10-2021   #23
lfalzarano
I can confirm that your stopping distances will increase dramatically as you go below 45F and the car can break loose in a tight turn at speed.
Old 03-10-2021   #24
Young1
Young1's Avatar
Motivos puckered me twice on the Cherohala in the summer. I felt I was not pushing it. Too hard at 500 and meant to last 50k miles. I used mine up in sliding and smoking at autocross. I did go 150 mph with them and it felt good.
Steve Young
Second Owner
SOLD
SOLD
Old 03-11-2021   #25
spork2367
Pretty sure they aren't even made anymore.
Old 03-28-2021   #26
evolutionross
I am running Nitto NT555's on my stock 1992. They are decent but lack the grip I was expecting. I also have a 2003 BMW M3 and it is running Continental Extreme contact. These tires, sadly not available in ZR1 sizes, are far superior for grip and handling to the Nitto's. Wet or dry, I have been underwhelmed by the Nitto's based on my expectations from the Continentals. I should note, that I have not finished replacing all of the suspension bushings on my ZR1 and this could greatly color the performance of a tire. The car with at Haibeck's now and I will be able to fully evaluate all of the cars performance metrics when we are reunited
I do plan to get the Pilot Sports as recommended above, when the time comes.
evolutionross is offline   Reply With Quote
Old 05-27-2021   #27
chesnut
Brought the Thompson MTT-6275 & 6278 Street Comp tires from Summit Racing. Have a couple of hundred miles on them and some in the rain. They handle and ride good. No flat spotting and their price wasn't bad.
Michelin still shows the 335 in production, but there were 0 available and Michelin couldn't tell me when they were scheduled for production.
Appreciate everyone's input. Thanks,
Gary
chesnut is offline   Reply With Quote
Old 05-27-2021   #28
lfalzarano
Tire Rack has 335/35/17 in stock. Amazon also has them.
Old 05-27-2021   #29
chesnut
All the major tire vendors listed the Michelin's but when you went to order them they quote delays. That was in mid March.
Michelin could've produced more since mid March.
Old 05-27-2021   #30
I have an appt @ TireRack in S. Bend to have staggered set of PS4s tires put on next Wednesday.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
