#1 | |
![]() Join Date: Jul 2020
Good advice. I only use copper plugs, none of those fancy platinum or iridium types which foul out easy if the coating on the tip comes off. Plus copper is a better conductor anyway. Just have to change them out every 10,000 miles on high performance motors. I will definitely do the plugs now. Not sure why I didn't pull them yet and inspect. I guess moving last year and losing my shop has really thrown off my routine! |
#2 | |
3000rpm w ~ 20% TPS is where ECM goes into PE mode. I had a similar issue a couple of years ago. Crossing into 3000rpm it would seem to breakup a bit then go on. It would act like a miss. |
Update:
Had read a story some months back about early LT5 engine failures and the discovery of a female at the plant who cold started every ZR-1 with her foot on the floor. The article didn't say anything about a cold engine rev limiter but I suspected maybe the ecu had one implemented after engineering witnessed this crazy abuse. I had lunch with the assistant chief engineer for the C8 LT2 engine in April (I grew up with him, friends since 5yo) and neither he or his boss knew for sure about possible 2nd rev limiter back in that era. And of course my car was too warm still after lunch to replicate the cold performance symptoms. Watch this video. At 13:30 he discusses the story I had read about and confirms indeed a second rev limiter was implemented! https://www.youtube.com/watch?v=6Vs2tdR-9C8&t=810s |
![]() Join Date: May 2010
Some believe you will have engine failure if you do not use AMSOIL!
Craig "ZR-1 NO KA 'OI" "ZR-1 ICHIBAN" 1995 #228 Black/Black with Dunn Heads ZR-1 owner since September 2003 ZR-1 Net Registry Founding Member #0074 NCM Lifetime Member #2048 ![]() |
I don?t think there is any limiter based on coolant C vs rpm in the calibration other than fuel and SA cutoff. May be that?s what he is referring to. I believe there are limiters based on oil temps but that would be for use of secondaries. Need to revisit the calibration Mask IDs to determine for certain.
