#21 | |
![]() Join Date: Dec 2003
#22 |
![]() Join Date: Jan 2009
Marc, thank you for the input. I understand that the stock computer has its highest rpm a fuel adjustment can be changed is 7,000. to get the engine "fueled" after 7,500, you need to trick it a little and after 8,000, there is no real way to alter the fuel curve. I was wondering if the engine was allowed to bounce or stumble above 7,500, if that would create the same jerking situation as a bad injector?? and if the chain was allowed to slap around long enough it would fail...
I was considering Jerry's chains, thought it might be a little overkill, but then again that is what I am trying to build, right? Jerry are those chains in a 350? and/or a big inch motors? Any feedback on how many miles they have gone or service life yet? And what about the crankshaft chain? any aftermarket progress on them? again thank you guys for all the info/input John |
#23 |
![]() Join Date: May 2007
An LPE Titanium valve spring retainer weighs 10 grams. The OE steel retainer weighs 19 grams.
The spark and fuel tables end at 7000 rpm. The last datum in the table applies from 7000 to 7500 rpm. I would expect that the system would use the 7000 to 7500 rpm value beyond 7500 rpm. |
#24 |
Marc,
Yes I agree, that is what I have found. the main tables allow for changes for 7,000 and they should hold until 7,500. after that you can't really put in exactly what you want. and thank you for the titanium weight information. so I am thinking with 9 gram on the retainer and then 24 grams for the lifters, I would be lightening the valve rotating weight by about 33 grams per valve. I think with the stage 3 cams and 7,500 limit, it might would make a tangible difference. I will be happy to report my findings if I ever get it together AND it runs..... I already have Jerry's cam followers ready to go in.. still on the fence about if the chains are worth the squeeze. I do not think there is ANY aftermarket crank to cam chain gears chains available.. Correct?? John |
#25 |
The OE type primary chain is all that you need. I have never heard of any problem using it. Install it with new facing on the tensioner.
#26 |
