No way thats an LT5 ECM
![]() Join Date: Aug 2015
You need a Tech 1 to diagnose.. there can and likely are more common failures that can cause your issue. Attached is the best I can do remotely. These are NOT common to L98/LT-1 platforms. They are unique to the LT-5.
See attached..20201109_134210.jpg20201109_134223.jpg20201109_134245.jpg20201109_134256.jpg20201109_134319.jpg20201109_134329.jpg Sent from my SM-G950U using ZR-1 Net Registry mobile app |
Lou is absolutely correct. The LT-5 ECM and DIS are not available in the open market. You are very likely looking at an LT-1/4 remanufactured unit. Won't work.
Sent from my SM-G950U using ZR-1 Net Registry mobile app Last edited by jss06c6; 11-09-2020 at 04:34 PM. |
![]() Join Date: Jul 2007
Rockauto has the WRONG ECM listed for the LT5, as do many of the automotive places (Autozone, Advance, etc)
Update: Had car shipped back from Austin a couple weeks ago. Austin Corvette tried a few things including cleaning ignition module connector. Car ran ok for a few miles, afterward, but then started missing again. Decided to ship it home and see if I could sort it out on my own. I read a post that suggested re-seating the EEPROM. Removed ECU today, reseated EEPROM and re-seated ECU connectors. Took it out for a 10 mile road test and so far it's running like a champ. Will let it sit overnight and run it from a cold start tomorrow. Crossing my fingers!
![]() Join Date: Jun 2020
Hope that's what it was!!
Well, after sitting overnight, started up this afternoon, and it's missing again.
![]() Join Date: Jan 2006
Check your alternator connection - not just visually but remove and clean if you can, plus check your battery terminals and check your alternator with a DVM.
#9 |
![]() Join Date: Jun 2015
Probably a good idea to check your battery connections as well. First rule of troubleshooting, start with the easiest thing first.
#10 |
..ECU is back from repair. Started up fine and drove it 60 miles no issues. Have a SES light, but when I check codes, I only get a Code 12. Start it up and the SES light returns?
