Old 10-30-2020   #21
musuraca
musuraca's Avatar
Default Re: Front & Rear Springs
Stingray1967,
I got both springs installed, and now the front of the car is sitting at least an inch higher. It seems to be too high. I think I'm even seeing a slight slant upward in the front. Please let me know how yours turned out.
Thanks,
Joe
Sent from my SM-G950U using ZR-1 Net Registry mobile app
94 ZR-1
72 LT1
16 Z06
22 CT5 V Blackwing
musuraca is offline   Reply With Quote
Old 10-31-2020   #22
Ccmano
Ccmano's Avatar
Originally Posted by musuraca View Post
Stingray1967,
Thanks,
Joe
At the risk of stating the obvious. Have you driven it since installing the springs? The springs and suspension need to settle after installation. Needs to be driven to do that.
H
90'ZR-1 #1461 Red/Black
05 C6 Z51 Red/Black Sold
Old 11-01-2020   #23
Stingray1967
Stingray1967's Avatar
Thanks Joe, the spring install took about 4 hours. I had a group of guys helping, and a local car guy who runs a shop provide the space. Immediately after installing, the car was sitting higher than I wanted. I took the shop owner for a blast up to 7,000 RPM on the freeway, and when we got back it is was sitting PERFECTLY. I know the ride height is probably too high for some of you guys, but for me it is perfect.
A huge thanks to one of the local MN ZR-1 guys (Matt) for lending his Saturday, and to the NCRS guys, and to the shop owner, Eric. For non-ZR-1 repair work, check out https://www.ericsrepair.com/ if you are in the Twin Cities area.
-Chris
Stingray1967 is offline   Reply With Quote
Old 11-02-2020   #24
musuraca
musuraca's Avatar
Looks good. Mine is about the same. A little high for me, but OK.
94 ZR-1
72 LT1
16 Z06
22 CT5 V Blackwing
Old 11-02-2020   #25
Stingray1967
Joe, does the front sit higher than the rear now? Mine did initially, before I drove it a bit.
1967 Corvette convertible, L79, 4 speed, red / black / white top
1994 Corvette ZR-1, white / black
NCRS North Central Chapter Judging Chairman
Old 11-02-2020   #26
musuraca
musuraca's Avatar
Yes, just a bit. I've driven about 40 miles. I hope it drops a little more, but I'm not sure a composite spring will change much. I'm satisfied now because I know it's correct, and not fractured like the old one.
94 ZR-1
72 LT1
16 Z06
22 CT5 V Blackwing
Old 11-03-2020   #27
Stingray1967
Good deal. Enjoy the car! I put mine away for the year the day we swapped the spring. New tires and alignment happening next year as opposed to this year. I didn't want the car sitting on brand new tires over the winter. Better to have it sit on the old tires.
