Old 09-12-2021   #21
Wigert
Default Re: Best Current Radiator Options?
Model: 32-1139090M (Manual)
I don?t recommend the single row.
https://www.dewitts.com/collections/...minum-radiator
Thanks for the quick reply! And with that one there is no need for any other modification except some trimming on the radiator supports?
Sent from my EVR-L29 using ZR-1 Net Registry mobile app
Wigert is offline   Reply With Quote
Old 09-12-2021   #22
HAWAIIZR-1's Avatar
Default Best Current Radiator Options?
You are very welcome. Yes, no mod but to trim the rubber cushion under the support housing. It is only because the radiator is two rows wide. You cannot see the trimming.
If you are a veteran be sure to ask for the discount. Maybe for other first responders too.
https://cdn.shopify.com/s/files/1/01...33825309578185
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
NCM Lifetime Member #2048
Old 09-21-2021   #23
Originally Posted by tf95ZR1 View Post
Why are you looking at another radiator?
Most times any cooling problems are remedied
by cleaning out and around the radiator.
You will be amazed at all the crap you collect
from a "bottom feeder". Plastic bags, critters,
Supras...
Totally agree. I got my NOS radiator from Pete who was swapping the stock radiator (which I now have in my Z) for an upgraded one for someone's Z. And, before installing the used stock one, I pressure washed (back flushed) it first. I kid you not, there must have been a quart container worth of sand and vegetation debris that came out of that thing! I've never had a heating issue with it since - even in stop and go traffic on 90+ degree days.
Old 09-21-2021   #24
sleazy rider
the po on my z put either a 2 row or 3 row, i have not looked to verify which one, griffen radiator in mine. the shroud had to be trimmed for it to fit properly but it is effective in handling the temp here in houston, tx.
sleazy rider is offline   Reply With Quote
Old 09-21-2021   #25
Wigert
Mine broke so that is why I am replacing it. But thanks for the input!
Old 09-21-2021   #26
bowtiguy
Placed an order with Ron Davis 7/1. Ten week lead time when ordered, expecting it any day. Car will get new silicone hoses along with a completely new R134a system while I'm in there. Probobly do a fan upgrade as well.
bowtiguy is offline   Reply With Quote
Old 11-22-2021   #27
bowtiguy
Just a follow up, I got my Davis radiator 3rd week of October. Your lead time may very. prob best to call. Then again, you do have all winter.
