Old 06-21-2020   #1
Perry Mitchell
Default Re: Eliminating the secondaries
This is how I keep my secondaries open at all times after removing the vacuum actuators.
File Type: jpg 79717B01-DDA8-455A-AC9E-9BE7D7265E38.jpg (177.5 KB, 78 views)
Perry Mitchell is offline   Reply With Quote
Old 06-21-2020   #2
Sooo... It appears you removed the actuator(s) and replaced them with a flat tab bolt, yes? Nice. Oh, but to be safe, it might be worth considering to dab some BLUE lOCKTITE on the threads under the nuts to prevent them from vibrating loose, resulting in the secondaries (possibly) creeping closed insidiously.
Old 06-22-2020   #3
Perry Mitchell
I used a 1/4'' threaded rod and flattened one end using a hammer then drilled a hole in it for the linkage pin to slip into. Loctite on the inboard nut might be a good idea. I used a nylon lock nut on the outside.
Old 06-23-2020   #4
grahambehan
Paul, et al
Engine made 528 hp
Ken owns the car that this engine was installed in.
I will put more info on the fb page, including video
Graham
grahambehan is offline   Reply With Quote
Old 06-23-2020   #5
Originally Posted by grahambehan View Post
Paul, et al
Engine made 528 hp
Graham
And this makes me shake my head when I read stupid comments on the C8 forum about how DOHC motors need to spun like a sewing machine to make any power. 528chp from a 5.7L NA motor. And one designed 30years ago.
Graham, what cams did u use for this?
Old 06-23-2020   #6
grahambehan
Power peak was at 7200 rpm.
Cam profiles were Lotus prototype.
Around 12mm lift, I think the duration was around 280 total.
I will dig out the info to confirm, don't have it with me at the shop.
Graham
Old 06-23-2020   #7
Paul, et al
Engine made 528 hp
Graham
Thanks for the clarifications, Graham. Much appreciated. And, if there are any dyno graphs available on that beast that you might have, I'll happily add them to my LT5 gen-III reference folder.
Paul.
Old 06-29-2020   #8
Just to add...
With regard to coking on the valves, I should mention too that in addition to secondaries delete, the installation of an OIL CATCH CAN was a notable contributor to the reduction of valve coking.
