04-10-2020 | #21 | |
Re: Radiators and Yorkie brushes
Thanks! I ordered an 1139090M.
I was confused because the Summit website mistakenly says it's not a fit for a ZR-1. Much cheaper here ($519.99 less $30 coupon = $489.99) than directly from DeWitt ($569.99). Quote:
'95 ZR-1, aqua/gray, #167 368 LPE/Haibeck, Web cams, Stainless Works headers, B&B Fusion exhaust, 18" Fikse wheels, Alcon brakes, lowered. 491 SAE RWHP. |
04-10-2020 | #22 |
FYI - dual core is about 1/4” thicker and will require 1/4” trimming of separation strip in the inside face of fan housing. Or, use of a spacer provided by Dewitt. Also, rubber support block on top and bottom will require trimming.
No big deal. You will understand when you read install instruction. |
04-10-2020 | #23 |
Thanks for the tip! Marc will be doing the install "while he's in there".
04-10-2020 | #24 | |
While at it, consider Spal fans and 200 amp alternator. Overheating in 96 plus degree days will become a distant memory. Last edited by secondchance; 04-10-2020 at 11:05 PM. |
04-11-2020 | #25 |
And while your at it, LED brake lights and have Marc double wire the 200 amp alternator to the battery and the AC blower, you will love the added volume of air out the vents. Mine went from 10 mph to 14 mph
