01-29-2020 | #21 | |
Re: Crazy VATS Problem
1995 ZR1 #159 Ported,Corsa,4.10 Rear, Dual Disc RAM Clutch, Alum Flywheel, Haibeck Chip, ZFDoc Plates, Relocated Battery 400 rwhp 1992 ZR1 #280 Ported, Locked Secondary's, Flowmaster Exhaust, Haibeck Chip, 375rwhp 1996 Collectors LT4 (Stock) 1972 Convertible 434 Small Block 572 rwhp |
01-29-2020 | #22 |
Crazy VATS Problem
Don’t rush to conclusions. When it didn’t start was it a lot hotter. Just trying to determine the circumstances when it fails to start.
Lou[COLOR="Red"][B][SIZE="4"][/SIZE][/B][/COLOR] Last edited by lfalzarano; 01-29-2020 at 10:11 PM. |
01-30-2020 | #23 |
Codes?
H
01-30-2020 | #24 |
01-31-2020 | #25 |
To be clear, no engine codes and no CCM codes? They are retrieved two different ways. VATS is under the control of the CCM module.
H
01-31-2020 | #26 |
I typically use a jumper and pull the codes from dash. I also have a reader that can also pull codes. I have disconnected the battery since it happened so chances are if there any historical codes they are gone now. I will double check.
01-31-2020 | #27 | |
H
01-31-2020 | #28 |
That is how I do it. Ground G to A on the ALDL connector. Thanks for uploading the pages. I wish I had the books instead of the CD's.
02-05-2020 | #29 |
Hey Guys,
Got in a 1993 ZR1 last week and wanted to disable the vats for the fella while we were replacing the CCM and was going to change the skip shift and fan settings for the fella. No big tune this time, just simple stuff. After burning the Chip I was able to get it to start and run no problem, but I had to install a resistor for the new bcm instead of the "simple" vats delete I so frequently do in all C4s. I could not get it to work no matter what I tried but additionally, the Tunerpro XDFs were kinda limited for this vehicle I noticed. Not sure which calibration I have, but I was wondering if any of you know of any problems with the Tunerpro XDFs or if (hopefully) someone can tell me where to get a better XDF with some more comprehensive maps and parameters for this and other ZR1s. Hopefully it's just the XDF I'm using, unless someone on here knows of a common VATS delete issue with these. Thanks a lot! Chuck CoW |
02-05-2020 | #30 |
The 93-95 ZRs use the $F0 altho most likely the $F0A .xdf.
