12-05-2019 | #21 |
Re: Careful with that camshaft
Quite awhile back, I purchased 31 LT5 engines the came out of a GM warehouse. Most of the engines were in some state of disassembly which included some loose cams with the sprocket still bolted to the cam. I put the cam in a vise clamping the hex end in the jaws to remove the sprocket/cam bolt. I didn't measure the twist in the camshaft, but it had to be in the 15~25deg range before I quit. Very spooky. After that, I would nest the camshaft in the cylinder head with the retainers & pin the cam with the timing pin. Works very well to remove/install the cam sprocket bolt.
12-05-2019 | #22 |
I bought an engine from a guy in Georgia; one of the cams had a bad snout, and then I got a bunch of cams from Dave Generous from the Callaway program and several of those had broken snouts
12-15-2019 | #23 |
I think I was told not sure by who, probably Jerry, to use the pins to hold the camshaft, instead of the rear hex head...I suppose theory is shortening up the distance reduces twist?
2009 LS9 1990 LT-5/sold/Bought my Baby back 1994 Lingenfelter LT-5/sold 1973 LS4/sold |
12-17-2019 | #24 | |
Will not work after you degree cam. Sometimes pin hole does not align after degreeing the cam. Pete
12-17-2019 | #25 |
After having degreed the camshaft with the sprocket pin in place, I use the following process:
1) Ensuring that the sprocket pin is in place with the sprocket washer and the camshaft sprocket bolt nipped up to around 50ft lbs, check if the camshaft timing pin J37326 will fit through the cap into the cam. 2) If the timing pin does not align with the cam, rotate the crank very slightly until it does align. Insert the timing pin to positively hold the cam from rotating. 3) Remove the camshaft sprocket bolt, clean the threads in the cam with a solvent to remove any oil etc and fit a new camshaft sprocket bolt, applying oil to the bolt flange only plus Loctite 262 to bolt threads only. Torque to spec (factory replacement bolt 19ft lbs plus 80 - 85 degrees) or Jerrys Gaskets ARP bolt 10090566 to 80ft Lbs. 4) To be very safe, you can also use a 0.020" strip of cardboard to fit between one of the temporary camshaft retaining caps and the cam, in order to further prevent any slight movement of the cam. 5) Remove the timing pin (and 0.020" strip of cardboard if used) and re-check timing.
Richard 1990, numbers 1821 and 2391 1821 - owned since Nov 2002, charcoal / Gray, Stainless headers, B&B system, 4.10's 2391 - owned since Jan 2019, Black / Black, have completed restoration. Jeal headers, Corsa system, 4.10's, Aluminum flywheel with Carolina clutch. |
02-25-2021 | #26 |
I figured I would share this that I figured out about the sprocket removal. I bought a disassembled engine and had the very same fear of holding the cam in a vise or the head an did not want to put any more stress anywhere that it did not have to be.
ironically, the cam chain is basically identical to every aftermarket ford motorsports 302/small block timing chain kit. from that ford motorsports kit I used the chain and crank gear. looped the FM/302 chain around the LT5 cam gear on one end and the FM/302 crank gear on the other end of the FM/302 chain put the whole set up into a vice and pinched the chain tight. looks like a figure 8. muscled the cam blot came right out with zero stress on the cam or the cam sprocket. Worked like a charm on all 4 cams. I ended up putting zip ties to help hold the chain around the crank gear. it was a surprise to me that the chains were pitch but a good surprise John |
03-01-2021 | #27 | |
Joe Thomas Corvette Club of Michigan NCRS-Michigan Chapter Member NCM Master Ambassador NCM Lifetime Member Former NCM Board Member 1991 ZR-1 Melon Copper Metallic/Black 1992 ZR-1 Bright Red/Black (Sold) 1995 ZR-1 Bright Aqua/Gray (Sold) 2012 ZR1 Super Sonic Blue / Dark Titanium |
03-01-2021 | #28 |
Ok we'll leave it at that 🤣🤣
Pete
