Old 11-14-2019   #21
Pete
Pete's Avatar
Default Re: Polycarbonate windows
Karl i use stock replacement battery.
I think about 30lbs
Just looked up Odyssey batteries i like PC950 only 20lbs
https://www.odysseybatteries.com/pc950.htm
Pete
Originally Posted by Karl View Post
How much does the stock battery weight?
I use the Odyssey PC925L and it weighs ~26lbs.
It is noticeable smaller and a AGM battery. Car starts right up.
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 11-14-2019   #22
lfalzarano
Remember the LT5 required 690 CCA according to GM. So choose wisely or carry jumper cables[emoji16]
Old 11-14-2019   #23
Karl
Karl's Avatar
You are getting the PHCA when you start the car. An AGM battery is way more efficient and powerful than a conventional liquid battery and has the ability to deep cycle.
Google AGM vs Lead Acid battery for more information.
It is pretty cold outside and my car is in the garage sitting for over 3 weeks. Car cranks strong, much stronger than the a/c delco that was in there before and fired right up.
Besides that daily driving the car before it got too cold outside (no heat in my Z) I never had a problem with charging or starting the car.
The battery Pete show's is stronger than mine and weights less by 4lbs. I should have gotten the PC950....argh!!!!
1993 ZR-1 #211 Yellow On Beige Beast #2
1992 ZR-1 #427 Black On Black *Sold*
1985 L98 Blue On Blue *Sold*
Old 11-14-2019   #24
lfalzarano
Default Polycarbonate windows
Yes the replacement battery at your local GM dealer parts department is a 650 CCA. After going through 2 of them in less than 5 years, I researched the LT5 690 CCA requirement.
The battery that will look stock and fit the battery box is the AC Delco 75VPG Battery. O’Reilly has them for $132. Weight is 33.7lbs.
Old 11-14-2019   #25
Locobob
http://www.zr1.net/forum/picture.php...pictureid=4061
About to try this 8lb lithium ion battery... specs are very similar to the 925
Robert
Old 11-14-2019   #26
RussMcB
Ouch!!! $559.99
Old 11-14-2019   #27
lfalzarano
You can join the Tesla burn your car crowd...
Old 11-14-2019   #28
Karl
Karl's Avatar
Originally Posted by RussMcB View Post
Ouch!!! $559.99
It is $509.99 on eBay w/free shipping....and yes...ouch!
Old 11-14-2019   #29
spork2367
How about this one? 5.8 lbs
Old 11-15-2019   #30
DRM500RUBYZR-1
DRM500RUBYZR-1's Avatar
Go on a bread and water diet.
Likely reduce by 50- 75 pounds, and if you don't die, completely reversible after racing.
The cars are pudgy; not much you can do about it, without consequence, at least significant improvement anyway.
Add more go.
Marty
