Old 10-02-2019   #21
frantinoro
Default Re: 1990 ZR-1 Issues
So, I took off the air setup, and noticed one seemed to leak slightly when sucking, and had a faint taste of gas. Can I just remove the diverter and connect the two together, or do I need to block them individually to delete the air setup?
frantinoro is offline   Reply With Quote
Old 10-02-2019   #22
If u disable the A.I.R., u also need to tell the ECM u r doing that. So a minor change in the calibration is called for.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 10-02-2019   #23
frantinoro
I was told that this wouldn't affect anything. Either way, I removed the diverter and connected the two together, and it honestly made the right bank more lean, or maybe I'm crazy. I'm open on what to test next. I noticed the cross counts for the left bank were like 10-15, vs the right bank was 0-2.
Old 10-02-2019   #24
richarde
You said originally that 'I got my zr-1 and it never ran right, but after sitting for a few months it's a lot worse'.
I guess that you purchased it earlier this year. Did you get any history with the car that could point to a resolution? Could it be a mechanical issue that is 'tricking' the sensors?
richarde is offline   Reply With Quote
Old 10-02-2019   #25
frantinoro
I did not get any history with the car no. I did notice that the INT creeps up ONLY at idle. I changed what I thought was my leaky check valve with a new one and no fix. Although I JUST found out both my resonators are cracked.
Old 10-02-2019   #26
BOTH??? resonsators Only one resonator (in the middle) & 2 mufflers @ rear. Are you perhaps referring to the catalytic converters, welded into the exhaust manifolds?
Old 10-02-2019   #27
frantinoro
Hi, yes both. I have a Corsa cat back. I doubt that would cause my issues though. What should I test next? I'm really stumped.
Old 10-02-2019   #28
If resonators are leaking they could suck fresh sir into the exhaust which could impact the operation of the O2s.
Old 10-02-2019   #29
frantinoro
Even though they're like 3 feet downstream?
Old 10-02-2019   #30
Its happened to me with a leak at the muffler. Idle and Decel are two pointa where engine vacuum is at its highest. It can pull fresh air past the O2s creating a “false lean” condition. That in turn will cause the ECM to richen the AFR.
