Old 09-14-2019   #21
Gunny
Gunny's Avatar
Default Re: 93ZR-1 no start
Steve & Russ -
I was hoping you guys would chime in. I suspect the two of you have probably forgotten more than I ever knew about the ZR-1 plus I gather you are both closer.
G -
Old 09-14-2019   #22
Originally Posted by Gunny View Post
Steve & Russ -
G -
Thanks Gunny, been a while.
Good to hear from ya hope all is well with you and your family.
Steve
1990 Steel Blue/Black #2355
1990 Red/Red #1473
1991 Quasar /Black #118 Sold
1993 Yellow/White #179 Sold
Old 09-14-2019   #23
RussMcB
Steve & Russ -
G -
You shouldn't even mention my name in the same sentence as Steve's. He's really a wealth of knowledge. Me? I just try to get by with the minimum. Thank goodness these cars were designed and built so well (once you get past the problems that other people have solved over the years).
Russ McBride, [COLOR="Red"]Car Sold 8/2020[/COLOR] #1635, Marietta, GA USA, 1991 ZR-1, #766 (bought 1/1/2015)
MS3-Pro, OBX, SW X-Pipe, Borla, Hurst, SLP, Goodyear F1 GS-D3, Kenwood. HOTB 2016Q3
[IMG]http://zr1.net/forum/picture.php?albumid=316&pictureid=2873[/IMG] [IMG]http://zr1.net/forum/picture.php?albumid=336&pictureid=2985[/IMG]
Old 09-14-2019   #24
Russ, you vastly underestimate your skills and overestimate mine LOL, If your able and 93ZR-1 will have us be great to see ya again.
Steve
1990 Red/Red #1473
Old 09-14-2019   #25
Originally Posted by We Gone View Post
Sorry I do all my own work, don't trust anyone in this area. I have only used Harc Haibeck for things i can't do. Having owned 3 ZR-1s over the past 20 years I have picked up a lot. With the help of this forum I have been able to fix all my own issues.
Feel free to search my posts here or on CF.
http://zr1specialist.com/
You guys can do it
Keep us posted as seems an interesting challenge with a possible obvious and simple solution
No spark or No fuel
Everything dried out in fuel system over 4 years and something stuck closed or an electrical contact got corroded..
Originally Posted by JG95ZR1 View Post
Check the passenger side fuse block and look for the fuse that says ecm before you send the car to a shop. It’s usually 3 or 5 amp fuse.
Yes.....check all fuses especially the INJ1 fuse
Old 09-30-2019   #26
Looked at the 93 that Joel owns this weekend. Long story short, Its alive removed and cleaned the fuel pumps fired right up. Got a few more issues to sort out next trip. car has been sitting for a while maybe over 5 years.
1. EGR code 32, I'm thinking the valve may be stuck.
2. Both service ASR and ABS lights are on. never dealt with this so any suggestions? Yes I have the 93 FSM but did not have time to pull the codes yet, will do next trip.
Everything else looks good the AC even still blows cold!
Steve
1990 Red/Red #1473
Old 10-01-2019   #27
tccrab
tccrab's Avatar
Originally Posted by precast1 View Post
There is only one guy South Georgia Corvettes, Aaron Scott they are located in Thomasville, Ga pm me if you can't find his contact info. He worked on my car before the C4 Gathering drove the car about 2000 miles. With 30 plus miles on the NCM 3.2 mile Road course. Also ran Mountain Run 7 with Gunny he did an amazing job putting the Mountain Run together I will be there this next year.
Sent from my SM-G950U using ZR-1 Net Registry mobile app
Pretty sure SGC is no more.
'Crabs
TomC
'90ZR1 #792
Honorary Pirate
[/B]
Old 10-15-2019   #28
Just a quick update, I have had Joel's 93 for a few weeks now. all the major issues solved (if you call fuel pumps, ABS/ASR lights on major) easy fixes actually and it runs like a top. One very nice completely original 93 40th with under 13k miles. Just needed a little TLC. When Joel picks it up I'm sure it will provide him many miles of smiles.
Steve
1990 Red/Red #1473
Old 10-16-2019   #29
93z
I have actually been smiling since the day I met Steve. The car is nice and I appreciate what it is but gaining Steve as a friend is much more important in the big picture. Thank you Steve
93z is offline   Reply With Quote
Old 10-16-2019   #30
carter200
carter200's Avatar
You need some bling.....
95 ZR-1
BLK/Gry
#392
LT5 Reg# 868 *RIP*
ZR1NET Founding Mem #155
