08-09-2019 | #21 |
Re: Driveway Bottom out
And if it’s a 90’ it uses the taller Z51 air dam. You can gain a inch or so if you use the standard air dam.
H Sent from my iPhone using ZR-1 Net Registry
08-09-2019 | #22 |
Increase aero lift. No way! Install one of those curb bridges or buy a C8... [emoji16]
08-09-2019 | #23 |
A 6’ plank will do the trick if you are only a casual ZR-1 driver.
08-09-2019 | #24 |
Thanks to our township I have issues with entering and leaving the driveway in just about all our vehicles. They resurfaced the road raising it up and at the end of the driveway they actually extended the road into the driveway opening creating a bad angle / overlap. I need to have my driveway redone so the contractor will take care of the issue. I have played with different ways of backing out to keep the left rear underside of exhaust tip from making contact with the road. They really caused issues for most of the home owners on our rural road. Hey what can I say PA. roads suck period.
91 Turquoise Metallic Haibeck 525 #0134 |
08-09-2019 | #25 |
The C4 front air dam was intended to be sacrificial over time.
When it gets torn up or worn down, just replace it. That's a lot cheaper than hiring a contractor to recontour your driveway. Zip Products sells C4 air dams for 60 bucks.
08-10-2019 | #26 |
Most liked what’s hittin the ground is the brace under the radiator,mine does it if I’m not paying attention going in my garage.
08-10-2019 | #27 | |
Ouch! I agree. There are certain things that are just worth spending on for the right/good stuff. Sent from my iPhone using ZR-1 Net Registry
08-15-2019 | #28 | |
Driveway Bottom out
The 2020 Stingray will be available with a hydraulic nose-lift option to avoid scraping the front of the car on inclines for $1,495.
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 08-19-2019 at 07:51 PM. |
