Old 05-09-2019   #21
ALLTHECAMS
ALLTHECAMS's Avatar
Default Re: Lean at high rpm
So I ordered Airtex e3240 pumps. Do they have the same connector as the stock pumps?
Sent from my XT1710-02 using Tapatalk
1991 ZR-1 #520 Arctic White/Gray
ALLTHECAMS is offline   Reply With Quote
Old 05-09-2019   #22
Ccmano
Ccmano's Avatar
Yup, your good.
90'ZR-1 #1461 Red/Black
05 C6 Z51 Red/Black Sold
Old 05-09-2019   #23
Reichert
Yes. I installed these same pumps recently. Pretty straightforward. Replace those plastic hose clamps too! You'll need both 5/16 and 3/8 inch.
-Stephen 1990 #2288
-Stephen
1990 #2288
Reichert is offline   Reply With Quote
Old 05-09-2019   #24
ALLTHECAMS
ALLTHECAMS's Avatar
-Stephen 1990 #2288
Gotcha. Thanks
Old 05-10-2019   #25
ALLTHECAMS
ALLTHECAMS's Avatar
One more question. Are the o-rings for the fuel filter the same size as the ones for the rail?
Old 05-12-2019   #26
ALLTHECAMS
ALLTHECAMS's Avatar
Installed the new pumps last night. Tested amp draw after and it was 9.5x. Took the car for a test drive and it lost power on the highway while testing WOT. Got a tow back home (luckily I was only a mile away). Tested amp draw again and it was 4.3. Primary pump isn't running.
Old 05-12-2019   #27
Reichert
Blown fuse?
-Stephen
1990 #2288
Old 05-12-2019   #28
ALLTHECAMS
ALLTHECAMS's Avatar
Blown fuse?
I checked the fuse and swapped it with another one. It's fine.
Old 05-12-2019   #29
Ccmano
Ccmano's Avatar
Bummer... when you pull the assembly again, check the connectors especially the one at the top of the of the entire assembly where the wiring exits through the top. Also apply 12v directly to the pump and confirm it is really dead. No need to replace the pump if it’s really something else. Most likely it’s just a bad new pump. It happens.
H
Old 05-12-2019   #30
ALLTHECAMS
ALLTHECAMS's Avatar
Thanks. Maybe a dumb question but which one is the primary? The lower one?
