03-31-2007 | #21 |
Re: Fuel Injectors
Maybe FF will come down for the party too-- "Kool---I am puting a vette/radio guys party together for the last sunday in july rain date 1st sun of aug at the McHenry Dam. I'll be sure u get an invite! It was a blast last year but only the radio guys--this year we add the vettes! Afternoon cookout party type of thing!"
http://i119.photobucket.com/albums/o...9mcw/SIG-2.jpg http://i119.photobucket.com/albums/o128/wb9mcw/vcm.gif "The Budget should be balanced, the Treasury should be refilled, public debt should be reduced, the arrogance of officialdom should be tempered and controlled, and the assistance to foreign lands should be curtailed, lest Rome will become bankrupt. People must again learn to work instead of living on public assistance." - Cicero, 55 BC " We the people are the rightful masters of both Congress and the courts, not to overthrow the Constitution but to overthrow the men who pervert the Constitution." - Abraham Lincoln Last edited by WB9MCW; 03-31-2007 at 04:03 PM. |
04-01-2007 | #22 | |
Re: Fuel Injectors
04-01-2007 | #23 |
Re: Fuel Injectors
OK. Tested the injectors today. Here are the results:
Primarys: Secondarys: #1 12.1 #1 12.1 #2 9.3 #2 12.3 #3 12.4 #3 12.3 #4 12.3 #4 12.1 #5 12.3 #5 5.1 #6 12.4 #6 6.0 #7 12.4 #7 12.0 #8 11.7 #8 12.2 From those numbers, I am going to guess I need some injectors. I know when we tested the pumps last year they were within the specs listed in the shop manual, but cant remember what the pressure was. Does anyone know if the Accel are stainlss steel? I cant find it on the description of the injectors. If not, I may go with the RC. I dont drive the car alot and I dont want them to rust. |
04-02-2007 | #24 |
Re: Fuel Injectors
I don't know much about the Accels. I would think if they were s/s that Accel would say that up front...sales gimmick & all. TCrabs & johnny phrogs used them...maybe a pm is in order? I do think that there is an o-ring kit from Marc that is needed for the early primaries to be replaced by the accels, but I could be off on that...I used the RC's when I did my 90...ya may want to check up on that too. Oh, Marc = zr1specialist.com = M. Haibeck.
While I had it apart I'd check the pumps again....I've bad luck when it comes to this "while we're here" stuff! But I think most of your #'s are nominal save for the obvious ones. Were those #'s cold or hot? Mine were easy, four of the 1* on the right bank just quit & all the 2* were gunked up @ the tips! Not to make work for ya but ya may want to go thru the 2* vac system and check the alt & starter & coils & wires & the CCV box gasket....ya know the while we're here thing again! Only reason I say to look at all that stuff is that the gaskets are expensive and all that stuff lives under them. If something else breaks under there shortly after....well ya know. Sorry to be so looong winded & not give any concrete answers! Tom
04-02-2007 | #25 |
Re: Fuel Injectors
Thanks for the info and you read my mind!! I was prob going to replace the vac lines and check everything else under there.
That test was all cold. I have not even run it this year yet. |
04-02-2007 | #26 | |
Re: Fuel Injectors
You will need to buy Marc's special "O" rings for the primary injectors on the early year cars. $20 plus shipping. If you're running a stock chip, yank it out and put in one of Marc's updated PROMS. You will not be disappointed. TomC '90ZR1 #792
04-02-2007 | #27 |
Re: Fuel Injectors
OK, need a little clarification here. I'm about to replace all my injectors in 1990 #1507 with Accels ($27 each at Auto Shop racing engines). I called Haibeck about these o-rings and he said the info is a little misleading and I don't really need them. So now I'm confused. Any help?
PS: I'm a new Net Registry member. |
04-02-2007 | #28 | |
Re: Fuel Injectors
I bought a set of Marc's special "O" rings when I replaced my stock injectors with Accels last year based upon this information: This probably belongs on a web site but I didn’t have a chance to add it to mine yet but anyway here is my story….and warning this one is a long one.... I was already cussing like a sailor when I found out that that I needed to replace essentially all of the injectors on a recently purchased 1991. Then when I found out that that you really have only a few choices: original stock “crap†with the same flawed design, rewrapped originals (aka MSD, and not avail for “correct†primaries for 90-91), or finally, RC’s. Also notably, most reputable “Injector Cleaning†services won’t service the originals because of the flawed design where the cleaning process itself has been known to kill them. Yes, there are some interesting conspiracy theories that GM pushed through these injectors knowing they were flawed to begin with but I won’t go there. Anyway, back to the story. With all options in excess of $1000 for a set of 16, my cussing turned into kicking and screaming since that $1K would come out of my “MORE POWER†budget. As longtime F-Body and L98 converts like myself can attest, a common mod/cost savings for standard TPI cars is to ditch the stock 22lb injectors in favor of the much cheaper “Motorsportâ€/Bosch style, so I started my investigation as to whether or not this would work on our Z’s. Initially, I came up with the same results as many before me. Bosch style can be used on the secondaries, but most are poor quality, and then you have mixed sets on of primaries and secondaries. Unfortunately they also don’t work on the 90-91 primaries thanks to the unique design with the O ring in the injector housing and the “offset†guide for the electrical connector clip. It is possible to “update†to the later style injector when used in conjunction with a larger O-ring in the injector housing but that only works with Lucas/Delphi/Multec style injectors that do not have the plastic end cap like Bosch do. So, after all that research, I planned to suck it up and buy RC’s. When I called RC in December 2005, they were out of the 205cc primaries until late March 2006. Crap, now what. Many just bought their 210’s during this time, but I already have a Haibeck chip designed for 205’s. Probably wouldn’t be a big deal to use to the 210’s anyway, but I decided against it. The plot thickens. It turns out Accel ditched their old style “Bosch†injector in favor of a new stainless steel body, Lucas style housing. You guessed it, it’s a comparable housing to that used by RC. Curious, I found a set of 8 “new†style Accel 21 lb/hr on eBay for $209, and since I had a few months, what harm is there in experimentation? When I received them, they did indeed look like a much higher quality unit than the old design, and knowing that the old style Accel units typically flowed more than rated, I sent them off to the very reputable Rich Jensen to get some flow numbers. Oddly, they flowed almost exactly 19.4 lb/hr across the board for all eight. That’s really great for me, but potentially really bad for Accel, since they are rated at 21 lb/hr. If you do the math, 19.4 lb/hr * 10.5 = 203.7cc, almost right on the mark for what I was looking for. I immediately purchased another set, yes on eBay again, and sent them of to Rich. To my amazement, Rich had the same results on the next set of 8. On top of that, the flow numbers for all 16 were so close I didn’t even need any “pairing†them to balance lower flowing injectors with higher flowing. Now to make them work: For the primaries, remove the lower O-ring on the new Accel units. Replace the existing IH O-rings with the larger O-rings from Marc Haibeck (~$20+ship). The lower O-Ring will seat against the slight taper on the Accel injectors (see photo). For later models you don't need the larger o-rings and needless to say, do not remove the lower o-ring. Just click for larger images... Use a razor blade to remove the plastic guide for the injector harness clip. Don’t worry, the guide is just that, a guide, the harness will still clip in place by using tabs on the sides. The guide was simply there so the primary and secondary were not swapped, but I’m not sure why they did that since it’s really difficult to stretch them to install them incorrectly. As for attaching to the fuel rail, simply use the original clip on the highest ring on the Accel unit(see pic above). Yes they do sit slightly lower in the rail but this does not impact sealing. The secondaries work without modification. What you need: (16) Accel 21# fuel injectors PN 150121 ($228-$248 for 8 right now on eBay New In Box) I think they run ~ $280 from Summit Large IH O-rings available from Mark Haibeck $20 (Sure you can probably get these elsewhere but Mark deserves the biz..) Flow testing of your Accel injectors just to be sure… $5/injector Total: ~$500 My 1991 is up and running in this configuration without any sealing issues on the injectors. I have yet to put it on the dyno to verify the A/F. My “seat of the pants o' meter†tells me they are working just fine, and yes, my seat is a very highly tuned measuring device. I am having a bit of difficulty with my idle a bit high but I’ve all but ruled out the injectors. Take this info as you like. This is simply the way I did mine to save a buck, actually over 500. I will post more details on a web site when I have a chance but I wanted to pass along the info since “Injectors†seems to come up regularly. I was hoping someone else might be as adventuresome and give it try to substantiate my claims…. To be honest, I didn't match up the originals to the ones I bought from Marc to see if there was a size difference. I just figured they were what I needed and was happy with that. If Marc said you don't need them, then you don't need them. However, having said that, it would probably be prudent to call him one more time and ask him "Are You Sure???". Marc is THE MAN and I would never question him on anything ZR1 (or anything else for that matter, but I digress). Maybe he's learned something since I replaced my injectors last year. TomC '90ZR1 #792
TomC '90ZR1 #792 Honorary Pirate [B]If it ain't FUN, you're doing something terribly WRONG. [/B] Last edited by Z Factor; 07-30-2007 at 06:06 PM. |
04-03-2007 | #29 |
Re: Fuel Injectors
So the Accels are S/S?? I did not see that anywhere and was not sure. Does it saty that somewhere and I missed it?
As for a chip, I do have a DRM chip. I do not know the specs as I got it with the car. I know it gets rid of the 1-4 shift. Other than the chip and a Samco air duct, my car is all stock and I was going to keep it that way. If them Accels are S/S, I think I will get them. |
04-03-2007 | #30 | ||
Re: Fuel Injectors
90ZR1 #792
